Smoke!!!
My Ride: 2004 530i, Sports Package, Premium Package, Nav, Logic 7
Hi guys,
I'm having an odd problem. I have a 2004 530i with 170,000 miles on it. It started blowing what appears to be white smoke a few days ago (a few times while accelerating at speed, while sitting at a stop light and at startup after sitting for about two hours). Obviously not a good sign, but the engine sounds perfectly fine. I thought that it might be related to moisture or coolant from my air conditioning system, so I turned it off for a day and drove 170 miles with no sign of smoke. At first I thought the worst, like a head gasket, but I'm not so sure anymore. Any idea what could be going on here?
Many thanks.
Many thanks.
Where is the smoke coming from ? Under your hood ?
Make sure you dont have oil leak at spools.. If you have leak there it will drop oil into your exhaust manifold = smoke
Hope you understand what was my point..
Assuming your white smoke is coming out of the tail pipe, I'd say your best bet is to have the car diagnosed by a BMW technician. If you can't find a trustworthy dealer, search for someone who works for BMW and moonlights fixing cars. This car - too many variables and they are all so damn expensive - you just don't really want to go by solely what people tell you on the forum. But assuming you don't have a 4-20 stash under that hood, and the smoke is coming from the tail pipes, it's likely a serious issue, could mean your engine block developed a microfracture, which is allowing coolant to mix in with oil. Could be water vapors in your gas tank from bad gas... I mean, just have the thing looked at by someone who will not rip you off. That's what I'd do.
Good Luck! Hang in there
And sorry I wasn't much more help.
It is coming from the tail pipe and it's definitely not morning condensation. This happens when the engine is hot. What I can't figure out is if it's a blown gasket or a cracked block, why would it stop when I turn off the air conditioning? I will be taking it to a technician. I'm just looking for what the possible causes might be.
Thanks again for the replies.
