5Series.net - Forums
-   -   smg owners (https://5series.net/forums/e60-discussion-2/smg-owners-5012/)
evperry Dec 2, 2004 10:04 PM
do most of u leave the car in gear or "n" wth the park brake?
JDN Dec 3, 2004 12:24 AM
Usually in gear will handle most Dallas situations. Other times I may leave in gear with the brake set. The only advantage to leaving in neutral, I guess, would be a quicker start up.
Rudy Dec 3, 2004 01:32 AM
In gear with brake every time (SMG or traditional cars.) That's what I've done since I learned to drive...
kigerka Dec 3, 2004 01:42 AM
Leave mine in "N" I am used to doing it in other cars. Besides it has to be in "N" to start it. However, if I am not on a pretty stable flat surface then I leave in gear.
subterFUSE Dec 3, 2004 04:23 AM
I leave my SMG in gear, and use the handbrake every time.
If you leave it in N and turn off the car, the dash light gives you a warning. I think BMW wants you to leave it in gear.
realtyman Dec 3, 2004 04:53 AM
I leave mine in gear (either forward or reverse) and with the parking brake on.
GER_545SMG Dec 3, 2004 07:13 AM
In gear...always
If PB fails you still have back-up.
bmwin14rsm Dec 3, 2004 07:15 AM
I leave it in gear and with the parking brake on. I have had problems with the system recognizing Neutral when I have left the car in Neutral for start up. I have found that when I start the car, it recognizes Neutral everytime when I have to take it from Gear to Neutral.
JDN Dec 3, 2004 08:46 AM
[snapback]63929[/snapback]
realty, is that black ice in that avatar? :wow:
realtyman Dec 3, 2004 09:00 AM
Originally Posted by JDN' date='Dec 3 2004, 12:46 PM
[quote name='realtyman' date='Dec 3 2004, 07:53 AM']I leave mine in gear (either forward or reverse) and with the parking brake on.
[snapback]64006[/snapback]
[/quote]
I hope not, JDN! At least there are no traffic control devices. :wow: :wow:
