SMG Manual Shifts
My Ride: G30 M550i
Model Year: 2018
Yep. And my rpm range is probably wider than what I originally stated above for the downshift from second to first.
It's all about feel, not an actual rev number. If you're braking fairly heavily, clicking the paddle at 2500 rpm as the tach is dropping will result in the downshift occurring at around 2000 rpm. If you're sort of coasting to a stop, then downshifting to first at 2500 will be excessive and you should probably do it around 2000 or 1800.
Pretty much anywhere between 1500 and 2500 rpm will work but too many other factors determine the exact point for maximum smoothness, etc. so it's hard to pinpoint one "all purpose" number.
These are some of the many issues that become second nature after the SMG learning curve is completed...
My Ride: 2010 750Li M sport
Originally Posted by EBMCS03' date='Oct 19 2005, 12:07 AM
[quote name='markt540i' date='Oct 18 2005, 12:48 PM']
? I am glad I ordered a manual.
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
[snapback]185840[/snapback]
HAHA why? too complicated for you?
[snapback]186015[/snapback]
[/quote]I just wanted to rile up you SMG guys and restart some good ole controversy.
![Innocent](https://5series.net/forums/images/smilies/imported/innocent.gif)
Originally Posted by markt540i' date='Oct 19 2005, 08:33 AM
I just wanted to rile up you SMG guys and restart some good ole controversy.? ![Innocent](https://5series.net/forums/images/smilies/imported/innocent.gif)
[snapback]186144[/snapback]
![](http://forums.e60.net/uploads/post-379-1104575721.gif)
My Ride: 2008 M5 -- Exterior: Silverstone, Interior: Black. Fully Loaded. That just about sums it up! :-)
[quote name='EBMCS03' date='Oct 19 2005, 12:07 AM'][quote name='markt540i' date='Oct 18 2005, 12:48 PM']
[/quote]Gotta Love It!
Some of the topics on this Forum make me feel like "sibling rivalry"!
My SMG equipped E60 is due to arrive next week. I can't wait!!!
-Tony
Originally Posted by drjochen' date='Oct 18 2005, 04:29 AM
There is no blip of the gas when the car downshifts by itself, but there is one when I downshift. All I hear is a metallic clang/click noise.
My dealer in its infinite wisdom tells me its perfectly normal. BMW NA is next...
[snapback]185629[/snapback]
When we manually downshift from 2 to 1 as we slow down the car blips the throttle and re-engages the clutch after shifting it into 1st gear, and that's when we feel the jolt. It assumes that we had good reason to do the downshift (e.g. to use engine braking or to accelerate faster), so it blips and re-engages the clutch immediately and is ready to go. However, if we let the car downshift from 2 to 1 as we are coming to a stop it just assumes that we are going to stop, so all it does it dis-engage the clutch and shift to 1, but then it does not re-engage again. This is why it feels smooth. Basically it just takes the car out of 2nd gear and puts it in 1 but will not re-engage the clutch until we accelerate again.
I think this IS mormal and it is doing what it was programmed to do....It also makes sense to me why they chose to do it that way.
My Ride: 2004 545i SMG, Dinan Flywheel, M Sport Kit Blk, Blk.
Originally Posted by rodybmw' date='Oct 20 2005, 12:00 AM
[quote name='drjochen' date='Oct 18 2005, 04:29 AM']There is no blip of the gas when the car downshifts by itself, but there is one when I downshift. All I hear is a metallic clang/click noise.
[snapback]186438[/snapback]
[/quote]Thanks, RODY
I am doing the same, as my manual downshifts at low rpms are jerky and can't be good for the transmission.
How do you like the B& B exhause - I am researching alternatives as I write this - I have purchased the m sport package (being installed this week!) Looking to dinan mountain view to install the flywheel next week, and had thought to purchase the schnitzer exhaust but I have noticed that there are many of you that have installed the B& B Exhaust.
What do you think? Volume, weight, perfomance gains if any?
My Ride: 530i 6 speed
But I don't think it normal that the entire car shakes and shudders and I hear a "bang" noise.
Originally Posted by Rudy' date='Oct 18 2005, 10:51 AM
[quote name='545smg' date='Oct 18 2005, 10:32 AM']I've donwshifted into first by accident on occassion going about 10 miles per hour and although it startled me, it was smooth!
[snapback]185687[/snapback]
I tried to experiment with the rpms and a manual downshift again.
If I do what you suggest (which I am sure works for your car), I get a huge "bobblehead" effect, the entire car jumps 1-2 times, just like when you drop the clutch too fast with a manual going from 2nd to 1st.
Another question is: when you drive in lets say 2nd or 3rd and suddely get off the gas, I feel 2-3 jumps in the car, if I get on the gas again, the same, both accompanied by a metallic clunck in the drivetrain. Does anyone have this? Again, I was told its normal. My previous manual E39 never did any of this....
My Ride: G30 M550i
Model Year: 2018
[snapback]186492[/snapback]
All I know is I seldom have any jerkiness but I usually keep any gas pedal movements smooth and steady -- especially in first and second gears...
