Smelly Air from the Air Conditioning
Old 03-22-2007, 10:22 AM
  #21
ronqureshi's Avatar
I am in austin Texas. Had the same problem in my 2005 530i after 1 year.
Took it to dealer. For free, they did the whole process with chemical vapors
recirculated thru ac system for a while. Caused by mold growth on the
evaporator inside the car blower system.
To prevent in future: They suggest to not use recirculation on your ac
control.
Hope that helps
Originally Posted by Yoko' post='401584' date='Mar 11 2007, 07:48 PM
Hey fellas,
My friend just bought 04 525i. he got some problem with the air conditioning. He said the air conditioning works well, but the air
is smelly. and it's especially when the first few minutes he turned it on. he asked me whether I know how to get rid of the smell.
Unfortunately, I have no idea about it . he also said that he's turned on the button for the inside air only and he has also
put a car perfume in his car. but it doesn't help much.
Anyone have any idea how to get rid of the smell? Thanx Guys..
Old 03-27-2007, 07:19 AM
  #22
BMWNA's Avatar
I'm with BMW of North America, LLC. I've checked with our experts regarding this issue. This is an industry wide problem caused by humid conditions. Moisture that condenses on the evaporator can provide an environment favorable to microorganisms drawn in either from the outside air, or from inside the passenger compartment (particularly from food or pets). This can cause a musty odor, when the air conditioner is first switched ON.
Using a specially designed tool, your BMW center can chemically clean the evaporator and evaporator box with disinfectant. However, while this can solve the odor problem for an extended period, it is not a permanent fix because the microorganisms can grow again due to the humidity in the air.
BMW recommends that you leave the A/C ON continuously (snowflake button on your A/C panel) to help prevent this situation from happening repeatedly.
Our engineers are still testing further options, but nothing new is anticipated for the immediate future. If you have additional questions or would like our assistance, you can reach us at 800-831-1117 or email us at CustomerRelations@bmwusa.com.
Old 03-27-2007, 02:52 PM
  #23
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Thanks BMW NA CR for replying with details, etc. I'm sure I speak for many here when I say that it is nice to see you posting more than just the "someone will be in touch with you about your problem" posts. (Not that they're a bad thing, it's just nice to see more!)
Old 03-29-2007, 06:07 PM
  #24
Biff Trout's Avatar
My Ride: 06 550-6spd
I had the issue too way down yonder in humid New Orleans. It is easily cured though the cure requires an additional step at shutdown.
When parking and exiting, I 1) shut off the engine then 2) turn on Parked Car Ventilation then 3) shut down the car. Parked Car Ventilation runs the fan for approx. 30 minutes which thoroughly dries the evaporator coil. Result - dry coil > no mold or mildew > no smelly AC.
Turning on Parked Car Ventilation is easy using I-drive shortcuts. Go thru the I-drive menu for Climate and end up on the Parked Car Ventilation screen. Shut down the car. Until you make a change to another Climate screen (I have not made a change to Climate through I-drive since initial setup in 2-06), the Parked Car Ventilation screen can be reached by moving the I-drive controller right then depressing and holding the controller for a second or two until the Parked Car Ventilation screen appears.
Parked Car Ventilation can only be activated between engine shutdown and car shutdown.
This sounds complicated in writing but is simple in practice. It adds about 3 sec. to shutdown. Once you get into the habit, it becomes second nature.
Old 03-29-2007, 06:11 PM
  #25
BOBUCRUZ's Avatar
My Ride: 2004 Black BMW 525i
Thanks for the directions. I got the same problem. Went to the dealer today for an oil change and mentioned the problem. They said $150 to clean it. I decliend at the time. Do you know if I start using this method if it will correct it, or do I need to have it cleaned first?
Old 03-31-2007, 06:40 AM
  #26
Biff Trout's Avatar
I have experienced the smell in my e60 infrequently in the past but no longer do. That is the best answer that I can give to your question.
Old 03-31-2007, 09:59 AM
  #27
bmw4life's Avatar
My Ride: Look At My Signature. -Other Rides and Previous Rides: 04 BMW X3 | 03 BMW 330i (Sold) | 05 BMW M3 (Gone)- 05 Infiniti G35 sedan, Premium Package, Bose Sound, HID, Sports Package, Hardwired Escort Passport x50 Blue Installed, New Transmission Installed, Navigation, Keyless Entry+Start Other Current Ride.
uh, using the trick i found on this forum was helpful to me and my car....
blast the heater for about 5 mins in FULL BLAST
then cool yourself with AC for another 5 mins and keep it on if you'd like
Old 04-02-2007, 04:41 PM
  #28
OU812545's Avatar
My Ride: -2004 BMW 545i. Silver Grey Metalic. with Black Int.: Sport, Navigation, Cold Weather, Comfort Seats, Logic 7, Heated Rear Seats, MP3 Retrofit. (Production date: Jan 2004) -2002 Porsche 911 Cabriolet. Seal Gray with Black Int. & Top: Tiptronic, Heated Seats, Bose Sound.
I had and still have this problem. A few months back, I had the car in for service and I told them of the "smell" problem. They did the chemical clean out and it did help for about 3 weeks. The long term fix is unclear. The dealer recommended that I turn off the A/C about 3 to 5 minutes before turning the car off. I did this and I still have the problem. I have tried several other suggestions from this forum, still with not luck.
I have a friend with the same car and he doesn't have the problem at all. The dealer said there is nothing else they can do for me.
(I hope the mold does not cause any health issues).
Has anyone seem this problem with any other types of cars or is this just with BMW?
Old 04-03-2007, 09:46 AM
  #29
jordan23junkee's Avatar
I can only suggest to maybe dry out with the heater before shutdown , but in 100+ degree heat its going to be tuff.
socale39
09-05-2023 08:30 AM
i545i
06-14-2015 06:36 PM
Stranger12
04-05-2015 10:42 AM
legalman
06-14-2004 05:49 AM
08-12-2003 11:41 AM
Quick Reply: Smelly Air from the Air Conditioning
