small oil leak on '06 525
Old 03-20-2012 | 02:38 PM
pipper's Avatar
My Ride: 2006 525
noticed 2 drops of oil on my garage floor this morning so i went to look for the culprit. pulled the big plastic shield under the front of the car and it had a good dose of oil on the passenger side...seems to have been there a while. also saw oil on the thermostat and water pump.
any ideas where it could be coming from?
(sorry for the weird angles on the pics)
Old 03-20-2012 | 07:29 PM
AchtungE60's Avatar
My Ride: E60 530i
Look like it's been a slow leak for some time. Take a photo of the source of the leak. It will be up top. on the second photo you have a tube showing and it look like also has oil on it so the leak should be above that. If you're really unsure where it comes from then with the engine cold spray some engine degreaser and let it work for about 15 min and then spray off...all of it and let engine dry a bit. keep an eye on it daily until you start to see oil.
Old 03-20-2012 | 08:26 PM
devildawg712's Avatar
My Ride: 545 modded the F out
Im gonna say it's the oil pressure sensor. That or the vacuum pump.
Old 03-26-2012 | 01:19 PM
pcy's Avatar
pcy
Look at the following closely-
Valve cover gaskets
Oil Pressure Sensor (next to oil filter)
Oil filter cover gasket (large o-ring)
Oil filter housing gasket
Clean the entire area with brake parts cleaner and monitor for new oil residue.
Old 03-27-2012 | 04:34 AM
pipper's Avatar
My Ride: 2006 525
thanks guys appreciate the replies. have cleaned it all and now im watching it.
user 4639202
09-23-2021 09:07 PM
YannickVT
05-07-2015 11:45 PM
demosthenesish
05-01-2015 06:02 AM
cointilt
03-30-2015 10:50 AM
andrek
03-26-2015 08:00 AM
Quick Reply: small oil leak on '06 525
