Slow Mechatronics Sleeve Leak
My Ride: '04 530i: Bone stock
My Ride: 530xi
I just did the whole job. It was $320 for 8 liters of the ZF fluid, new pan, gasket, plug and mechatronics sleeve shipped from California Trans Supply. My mechanic took 4 hours to do it and a transfer case fluid change and had no problems using the procedure from CFTC and charged me $280.
All in all $600 for new sleeve, pan, gasket and plugs. I am very happy and the trans seems to be running smooth as ever at 114,000 miles
My Ride: 2007 ★ Alpine White
Here is all the parts I am spending on to do the oil pan and other maintenance work. Labor is going to cost me about $450 to do everything from an indi certified mechanic who works for BMW. There are 2 oil leaks, one at the oil filter housing on the left side of the engine block & one at the transmission mechatronics sealing sleeve. The stealers wanted about $2300 to do the job.
24-11-7-571-217 OIL PAN W (1) -- $133.97 ZF
24-11-7-552-108 TORX SCRE (24) --$43.44
24-34-7-588-725 SEALING SLEEVE (1) --$13.66
83-22-2-220-445 TF 1375.4 (6 liters) --$162
11-42-7-525-335 GASKET:11 (1) --$9.06
11-42-7-537-293 GASKET:11 (1) --$9.06
11-53-7-549-476 Thermostat + the screws (1) -- $77.15 INA
11-28-7-530-314 Mechanical Belt Tension (1) -- $77.93
11-28-7-628-650 Belt (1) -- $28.77
BMW Coolant (2 Gallons) -- $37.12
SAF-XO (2 liters) -- $40.00
spark plugs FR7NPP332 (6) -- $58.25
