Slight Headlight Housing Damage
Old Nov 17, 2008 | 06:01 AM
Idonkare's Avatar
My Ride: 2005 (01/05 Build) Titanium Silver Metallic 530i, Black Dakota Leather Interior w/Dark Poplar Wood Trim, Cold, Premium & Sport Packages, Steptronic, Bluetooth MODS: OEM 166's (M5 Offset) on General's (245/35 & 275/30), 15mm H&R Spacers, Auxiliary Audio Input, 6000K Xenon Headlights and Matching HID Fogs, AIB v3.0, SprintBooster, OEM LED License Plate Bulbs, Smoked LED Side Markers, Matte Black Kidney Grills
So...while attempting to change out my headlight bulbs, I somehow chipped off a piece on one of the headlight housings. It's not the side of the housing where the light emits from, but the housing that faces the engine bay. To be more specific, it's part of the rim where the removable cover sits (angeleye/high beam compartment on a MY05 - adaptive xenons).
Everything is functional but my concern is the inside of the headlight is exposed (about a 2 cm hole is visible). will just patching it up with some electrical tape be fine or are there other things that i have not considered that could cause a problem. I'm thinking i should be fine but just wanted to get some additional input. Thank everyone
Old Nov 17, 2008 | 06:05 AM
luigi524td's Avatar
Your concerns are valid.
Solution, in a word, SILICONE! Caution, some will do not adhere well to certain plastics.
Old Nov 17, 2008 | 06:06 AM
littlemouse's Avatar
My Ride: Week 17 Build, 2008 E60 535d M Sport - Titanium Silver, Black Dakota Leather, Visibility Package, Media Package, Automatic gearbox, Steering Wheel Heating, M Double Spoke 172 19" Mixed Wheels, Auto-Dim+Exterior Mirror, Comfort seats, Front Seat Heating, Aluminium Pentan interior trim,DAB Tuner, TV Function, BMW Individual Audio System 825W !!
In my old E61 I dropped the rubber cover from the back of the lamp housing and could not retreive it, so I covered it with electrical tape, and it worked fine... I'm sure yours will be the same...
Old Nov 17, 2008 | 06:40 AM
mrfva's Avatar
My Ride: .
Model Year: .
Both electrical tape and silicone should suffice, but I would lean on using silicone. There are several types for different materials. Get the one specific for your needs and you should be good.
Old Nov 17, 2008 | 06:47 AM
ENstig8or's Avatar
My Ride: 650 Grand Coupe
Model Year: 2016
+1 on the silicon. You don't want any moisture getting in there.
Old Nov 17, 2008 | 08:05 AM
flyingpuck's Avatar
Will this really work???
Old Nov 17, 2008 | 08:16 AM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
Attachment 64893
Only if properly applied...
Old Nov 17, 2008 | 08:23 AM
radzM's Avatar
that will definitely work!!!
Old Nov 17, 2008 | 08:29 AM
BALASUBAS's Avatar
if your car is still under warranty why not try to talk to your dealership and maybe they'll replaced it?? just don't tell them that you played around with it, coz with me i asked my dealer to change my shift knob that has scratches, i know its just a shift knob but they gave me a brand spanking new one just try it! good luck!!!
Old Nov 17, 2008 | 09:25 AM
Veight's Avatar
That person used waaaayyyy too much silicone on those headlights. The hole to be filled was way farther down too.
