Shhhhhhhhh
My pet hate is interior rattles. My previous car, C class Merc, had a very load dash vibration at low revs that drove me insane. So to my horror the 5er developed a very loud vibration/rattle at low revs a couple of days ago. The sound was coming from the driver side footwell area, I tried pushing, pulling and punching all over the place to no avail. So today I removed the lower dash panel and went for a spin, no vibration. Had a closer look at the panel and one of the metal clips at the front was loose and rattled when I tapped on the panel. I tightened it down with pliers, then I sprayed a tiny amount of silicon lube on all the clips and mounting points. Put all back together and voila, the noise has gone.
Now I was on quest for pure silence, the rear arm rest rattles a lot in the 5er. Even opening and closing it creates a rattle. I took the plastic surround off the lock and cup holders and found a small plastic jewel from someone?s cheapo jewellery stuck inside the lock. After some Beyonce style jiggling I managed to get it out. Again gave everything a fine coating of silicon lube and again, the noise has gone.
So this got me thinking the door seals were also a little noisy at times, broke out a cloth and the trusty silicon lube (I love this stuff). Wiped over all the door seals and went for a drive. All I can say is wow, for the first time I have no rattles, squeaks, creaks or vibrations. I turned the radio and aircon off and it was a lovely drive.
In conclusions there is no real point to this story other than to keep your rubber lubed and don't buy cheap jewellery.
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
door seals are a known issue for causing some cabin noises...glad you got your rattles, squeaks, and creeks resolved so easily...a few other posts mention this same remedy as well
Lol, my dad has a Toyota Avensis and it is actually quite good. Only noises he has had are seat rubbing against arm rest, rattling fuse box door, vibration from behind the sat nav screen and a scraping sound when turning the steering wheel
I had some annoying creaks and squeaks for a while and I thought I could live with it until I tried this method. I went to the local hardware store and bought a can of Dupont silicone with teflon. It was a spray kind so I took a piece of sponge and sprayed it first then took it to every nook and cranny of the door seals. Took about 30 minutes to give them 2 coats each. And now, the car is quiet on turns and bumps like a 007's silencer. Thanks for the tip.
