SES light - engine emissions
Took my car to the dealer to look at a service engine soon light that said "increased emissions." The response from the dealer is to "replace Y hose and secondary air valves (secondary air Y hose leaking)." Apparently my "factory type" bumper to bumper after market warranty isn't planning to cover this. The cost is $1,313. Is this something I can do on my own with aftermarket parts?
Anything you can offer quickly would be great because I need to call the dealer back on what to do with the car. Thanks!!
So far I found another shop that can do the work for $590. Still shopping... if anybody has removed the intake and can offer some advice on how difficult it is I would appreciate it. The shop is calling for 5 hours of work.
My Ride: 545i
Bump!
I just go this error now, so anyone know the exact problem? I will take it to my indy shop and have them replace whatever it is. Hope it's not the catalic converter!!
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
I had the same happen to my 750 I just reset it in my Idrive and all is good. I dont really care to spend 1300 or so for something stupid like that. BTW - I had mine happen around 70K on the odo.
My Ride: 545i
Thanks Syrousd! How do you reset it in iDrive? And does it affect the emission test results when I take it in? Mandatory here in Ontario.
Thanks again!
Thanks again!
My Ride: 545i
I spoke to my mechanic, and changing the pressure valves is very important in this case, because it may cause oil leaks and gasket issues.
He said the cost may be $500 to $600, I'm going to do it.
My Ride: 2004 BMW 545i Silver,Gray, Metallic. Blk Dakota leather. Nav. Heads up disply. PDC. Pro logic 7 sound. 35% tint.
Mods. MTECH body kit. OEM trunk finisher and M5 spoiler.OEM 166 wheels. Blk and wht CF Roundels.
Orion V2 AEs. LCI taillights with Ricky effect. LED interior lights. LED license plate light. HID fogs. Smoked LED side markers. White cluster mod. Coding. RPI scoop & BMC filter. Gloss black OEM grills.CF interior trim. B&B exhaust.
I had the same error and mine was a thermostat.
Cost me About $200 total.
it is date driven in 750 it passed the so called inspection date and was overdue...so you just reset the date...again that was in a 750...
The car never did overheat. We even checked the coolant temp on the diagnostic unit a couple
of times when we cleared it and the temp was right on.
Decided to go ahead and do the thermostat anyways and the code hasn't come back.
