Service Bulletin for new 4.8L engine
SI B 12 27 05
Engine Electrical Systems December 2005
Technical Service
SUBJECT
N62TU - Engine Pinging & Idle Fluctuation
MODEL
E65, E66 with N62TU from 03/05 up to 12/05
E60, E63, E64 with N62TU from 09/05 up to 12/05
SITUATION
Customer may complain about two different, drivability related situations:
Engine pinging ("dieseling") on slight acceleration under the load at low vehicle speed (35-40 mph).
Excessive idle speed fluctuations (1100-1300 rpm) on a cold start for the first 30 seconds of engine operation, when transmission is in P or N position.
CAUSE
DME software calibration for knock sensors sensitivity and catalysts preheating.
CORRECTION
On a customer complaint basis only, reprogram and recode complete vehicle with CIP 20.0, or higher.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
CORRECTION
Seems like there are two Service bulletins out for V8 E60's out now.
The other one would be this.
Even it this doesn't consern me, thanks cobradav
This is what this Forum is about
My Ride: 2008 Sapphire Black on Black M5 - loaded sans soft close doors
Any clue what "Excessive idle speed fluctuations (1100-1300 rpm) on a cold start for the first 30 seconds of engine operation, " could mean?
I notice that my car starts up at a very high idle and just about 30 seconds later will drop down significantly - or when I put it in gear. No dieseling however.
My Ride: 2011 E92 335i M-Sport 6MT
Although I haven't (yet) experienced this, I assume the manual transmission is exempt based on the description where "transmission is in P or N position"??? Interesting that only a 200rpm change in idle speed would be considered "excessive". Any clarification to the above bulletin regarding what transmission types are truly affected? Or is this solely for Steptronic-equipped cars?
This is what this Forum is about![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I guess the following includes the E60 550i: "E60 (5 Series) 545i, E63 and E64 (6 Series) 645Ci and 645CiC, E65 and E66 (7 Series) 745i and 745Li, E53 (X5) 4.4i and 4.8is equipped with N62 engine."
The exposition is not clear to me, but, IMO, your inference is correct unless the N62 engine is not the one that's in the 550i or there is some difference in the 4.8 N62's in the E53 X5's and the E60 550i's.
[/quote]
N62 = 4.4L
N62TU = 4.8L
So this bulletin is for the 4.8L engine in the chassis identified and not the e53 4.8L engine which has a different code
My Ride: 530 2006
msport package, steptronic, pdc, mystik blue, grey dakota leather, sunroof, Bi-Xenon, heated rear seats, Hi-FI system, velour carpets
Thx for sharing the info.
N62TU = 4.8L
[/quote]Thanks, so this bulletin does not apply to the 550i, right?
