Serious wheel shaking
With my new OEM M172 wheels and tires (see my sign down below for details)
I have a really bad "car shake" if the car has not driven for a few days.
It's not a small quiver that one feels in the steering wheel, but a shake down.
After some 5 miles or so driving, the "car shake" seems to end.
But even after that the empty passenger seat seams to have it's own party,
and the whole car kind of trembles but the steering wheel is "easy".
Did go for higher tire pressures but it didn't help.
Seems like the rear 275/30 19" wheels are not in balance but is there anything else wrong?
Originally Posted by 545iBMW' post='596249' date='Jun 5 2008, 08:43 PM
Did you get it balanced when you had it installed?
When is the last time you had your tires balanced?
Are they tightened/torqued properly? I mean your rims.
No, but the wheels and tires are brand new.
They came (from Germany to Finland) installed and balanced, but with a lot of "install grease" on them!
Tightened and torqued properly.
At first is sounds as though your tires are developing flat spots from being parked for a few days. After driving for a bit the tires heat up, these flat spots round out and the problem goes away. I think mild flat spotting pretty normal with soft tires.
But your problem seems to be more serious than this, I would definetly have someone take a look at it.
A salesman from my local tire/rim store once told me that tires that are stored vertically rather than horizontally will eventually loose its right shape. So, I would think your tires might have been an old stock (even thought they are new) and was improperly stored. Or was shipped to you via ground and was stowed vertically in a delivery truck.
Have your tires balanced again to make sure your tires are perfectly round and in good shape.
My Ride: 2008 BMW 550i Sport
Carbon Black Metallic/Cream Beige
Manny tranny and other stuff
Recently gone, but never forgotten:
2005 Ford Mustang GT (hence the name)
Torch Red/Crimson
Manny tranny and every option available for that year
2002 Chrysler 300M Special
Brilliant Black/Light Taupe/Dark Slate
Autostick and goo-gobs of neat features that I will sorely miss
Your tires are simply suffering from flat-spotting. No real harm being done. Mine flat-spot if I leave it sitting more than a day. My passenger seat has the Shakemaster 2000 installed in it, too.
My Ride: Bmw 530d 2004
I had couple of bad tyres except they were new. Even though the balancing machine was giving good readings, you could see the unroundness of the tyre. There were about 1mm throw that could be seen when spinning the wheel.
You could ask the technician to spin the tyre on the wheel 1/2 round and rebalance. Sometimes this helps. As you know very well, BMW's are very sensitive to this kind of issues.
I ordered those bad tyres from Germany too (Rengas-Online). I reclamated and they send me another pair of tyres. It took half a year waiting the decision from the manufacturer if the reclamation was rightful or not. Eventually they replied it was, which I knew all the time...
My Ride: G30 530i M-sport
Model Year: 2018
Thanks guys This is the Forum!
But flat spots can't be the answer, I just will not take that bull****.
These tires are made for a market of everyday drivers.
So, this is an example of what the small problems of net-shopping can be.
It's not that easy to go and give your reclamation to a person/company
some thousands of miles away.
But some chatting will be done between the seller an me.
