Series of codes on my e60 with rough idle
Hey what’s up I’m new here and have some issues
2A2F Mixture control 2 2D06 Air-ma55 System 29D0 Combustion misfires, cylinder 4 2A82 VANOS intake 2DOF Air-mas5 Sensor, Signal 2A87 Exhaust VANS, mechanism 2F08 replaced return hose on crankcase was broken also just replaced MAF sensor but still have the 2D06 code also replaced sparks and coils but still have misfire on cylinder 4 don’t know what else to do it seems to get a better still wants to stall on me when stopping at red lights or stop signs rpms move slightly up and down but a couple rpms if anyone knows how to help I would appreciate it |
1. Was a smoke test done on the car? If not do one.
2. Are you using OEM parts? If not then you're wasting time with troubleshooting because aftermarket don't work as they should on BMWs when it comes down to parts that make the car run. 3. How does the car act when MAF is disconnected? 4. What are your fuel pressures looking like? What are the number on your injectors if you have the system to read them. |
| All times are GMT -8. The time now is 06:55 AM. |
