Sensor
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by Tsandas' date='Jul 21 2004, 07:58 PM
Anyone know what the sensor is located behind the rear view mirrow? Not the ones on the window, there is one right behind the rear view mirror on the right side.
Picture below, as posted on the other thread shows:
1) Is for the automatic dimming of the rear view mirror. It measures on this sensor and on the one you can see when looking at it from the other side (the correct side ).
2) I'm pretty sure it's the sensor for the automatic lights.
3) I think this is the rainsensor, since it's bigger/wider than 2, and it's harder to detect rain, than to detect the sunlight.
4) It looks like a vent for the heat of the electrical components.
still not sure about #1 -- doesn't make sense that it would be on that side for the anti-dazzle.
my anti-dazzle (rear & sides) seem to kick in when required based on the lights behind me - and they 'un-anti-dazzle' when the light source behind me goes away
Model Year: 2013
There is one on the other side too, the little dot in the upper middle...
Refresh me again on the function of the little black stud sensor on top of the center dash speaker. Also, on #3, when inspected with a light, shows eight little red reflectors -- four above the blue sensor and four below. Any ideas on their function?
Originally Posted by Iceman' date='Jul 21 2004, 01:24 PM
[quote name='skidster' date='Jul 21 2004, 09:17 PM'] still not sure about #1 -- doesn't make sense that it would be on that side for the anti-dazzle.
There is one on the other side too, the little dot in the upper middle... [/quote]
i understand that that is what people have said.
what i do not understand is why.
by definition, the anti-dazzle mirror function is designed to dim/un-dim (adjust reflectivity) based on the light shined into the surface of the mirror.
what function is performed by a sensor located on the opposite side of the variable-reflective surface?
enquiring minds want to know...
Model Year: 2013
It knows because it has another sensor on the other side what measures the intensity of the light on the other side, the front of the car.
So, when there is too much light from behind, it dims.
It needs two sensors two notice/measure the difference.
Model Year: 2013
Here is a quote from the other thread:
the black piece sticking up on the dash is sensor for direct sunlight. If there is direct sunlight, the computer will adjust the AC to keep up w/ the greater heating of the sunlight.
The number three, I believe, is the rain sensor. It measures the intensity of the rain.
Originally Posted by Iceman' date='Jul 21 2004, 02:06 PM
[quote name='skidster' date='Jul 21 2004, 10:02 PM'] i understand that that is what people have said.
It needs two sensors two notice/measure the difference. [/quote]
i would store iterations of old current state
and
compare it to current state
makes more sense to me...
just because i am driving in an area with streetlights (illuminating the front sensor) i do not want any less anti-dazzle action when a prat with high beams and fogs comes in behind me...
so, and pardon me if i am thick (but that is not a usual situation) but please tell me again just why a comparison with the light in 'front' of the car is in any related to the dim/un-dimming of the side and rearview mirrors as a consequence of light being shined into them, at street level, into their sensors (the ones on the shiny mirror-like glass reflective surface of the mirror :-) ?
