Sea Foam?
My Ride: 04 BMW 530I
Sea Foam?
I want to put sea foam thru my vacum lines.... i think thats where ur supposed to. is this right?? or is it not recommended on these car? any tips or ideas on this? if so where r the vacums lines or the lines its supposed to do? i have a 04 530I e60, thanks
well i changed th oil on my car the other day and there was this gunk on the oil cap... so just want to clean the motor a little, could this stuff be causing my car not to glide when i let go of the gas pedal? it feel like it slows down a lot after i let go of the gas pedal
Buddy Seafoamed his Mazda CX9 and had to take it to the shop after. Wrecked his O2 sensors. And per above, he smoked out the whole neighborhood (albeit commercial area).
My Ride: 2008 LCI 535xi
seafoam goes in the gas tank, open ur oil cap and pour some in, and where ur pcv valve is let that suck some up to get into the head. i used to do a can in the tank, half a can in the oil, and the other half let the pcv suck up. it smokes A LOT when ur drive right away but then it goes away. do not do it with ppl behind u
My Ride: 2006 535d Sport
