Running 20 x 8.5 on rear wheel with spacers?
My Ride: 2004 545i
Will running 20 x 8.5 with spacers on rear wheel possible and how safe will that be?
rim specs:
Offset: +16mm
Backspacing: 5.43"
Bolt Pattern: 5-120
rim specs:
Offset: +16mm
Backspacing: 5.43"
Bolt Pattern: 5-120
My Ride: 05' 545i
probably wont find a better or more active "5 series" forum. Maybe they viewed and could not provide an answer?
I have 20/10 in the rear..no spacers with a 20 offset. tire app is 285/30 and they rub on major dips and when people are in the car. I used bumpstops to relieve the rubbing until I get 275/30 tires....Hope this helps you out
