Run Flat Tyer Puncture
Old Dec 9, 2005 | 03:17 AM
Memotronic's Avatar
is it nomal ... to have inner side of tyer gone more than outer ? do I have to do any kind of balancing ?
Old Dec 9, 2005 | 03:20 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I assume those are rear tires and if so, then it's pretty normal for the inside edges to wear before the outside due to the negative camber of the suspension system on our cars -- they're just not supposed to wear that much because you're supposed to get new ones when they get low...
I'd say you drove on those things a bit too long!
Old Dec 9, 2005 | 03:25 AM
browellm's Avatar
Very diplomatic Rudy
Old Dec 9, 2005 | 03:31 AM
Memotronic's Avatar
Yes it is rear tyer for 545i , and I used them for long time , becuase road work is going on in my area and they will finish it in copule of month. any way .. I did not follow some fiends advice in driving with punctured RFT tyer because my car is supplied with spare tyer ...
Old Dec 9, 2005 | 03:47 AM
radioham's Avatar
My Ride: 640D MSPORT GT
a bit too long!!!!!!!!!!!
less than 2mm tread is threshhold to change ,in my opinion,?40000.00 running on that,what price your life.
runflat--------------run on what? your rims
you must be teasing us.
forget balancing---try juggling!
Old Dec 9, 2005 | 04:36 AM
colejl's Avatar
Ah, Dunlops... Say no more - not a great tyre! :thumbsdown:
Wear looks normal as the rear camber will wear the inside edge more than the outside. But as already noted regulars checks are required on all of the tread (I'd recommend 2mm minimum too!)
Time to buy some 'decent' tyres... Let's say Michelin PS2's
Old Dec 9, 2005 | 04:58 AM
znod's Avatar
Yes, you drove on them a bit long.
Old Dec 9, 2005 | 07:55 AM
colejl's Avatar
Bet the dry grip was great with those slicks
Old Dec 9, 2005 | 08:08 AM
Ricracing's Avatar
I have never seen a tyre that worn! Great pics
But I know how you guys ride your cars know there, I'm not surprised what they get worn out,
and in those conditions the RF tyre comes to value!
I suppose the car was driven something like 15,000 km???
Old Dec 9, 2005 | 08:55 AM
Freewilly's Avatar
My Ride: 2013 535i (White with Oyster Interior. Premium Package, Navigation, Technology Pacakge, Park Distance Control, and Rear View Camera)
You do get your money worth on those tires
