RPM actin crazy after a new MAF installed ?
Old 03-11-2017, 08:58 PM
OSI550i's Avatar
My Ride: 2008 550i E60 Blue W/Sport Pkg 19' wheel
Hey guys. I was wondering if someone have any information about the torque specs for the pulley if i took it out and replace it with a new one for my 2008 550i N62 engine ?
Old 03-18-2017, 12:26 PM
OSI550i's Avatar
I have installed the new alternator with the new pulleys as well as the belts ! However, when i first started the car the squeaking sound was LOUD ! Do you think guys it's from the torque that i have not get it right or the alignment was wrong ! any thoughts ?
Old 03-20-2017, 09:21 AM
OSI550i's Avatar
JUST WANTED TO UPDATE FOR PEOPLE WHO HAVE THE SAME CAR AS ME AND WANTED TO DO THE TORQUE SPEC FOR THE TENSION IF YOU ARE PLANNING TO CHANGE IT HERE IS THE EMAIL I GOT FROM FCB EURO :
Hello.
Thank you again for your patience while I worked on your request. The specific torque needed is 38Nm. If you have any questions regarding this information, please feel free to reach out to our products department. They are always happy to help with technical information, and may be reached at products@fcpeuro.com.
Warm Regards,
Tiffanie Hrabe
Customer Service Advisor
FCP Euro
Quality & Service, Guaranteed for Life
HOPE THAT HELPS
Old 03-20-2017, 03:00 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I have never used factory specs when torquing. It might be wrong but after 15 years I have never had a problem. Squeaking usually comes from either a bad belt alignment or needing to be tightened/loosened depending on what type of tensioner you have. I think these are auto adjusting could be wrong so it would have been the alignment or lack of having a v ridge belt which makes things easier for me. Not by any means am I a mechanic but I have formulated my own conclusions on certain situations which have worked for me.
Old 03-21-2017, 09:06 PM
Cricketts's Avatar
My Ride: 2010 BMW 550i M Sport. GPS, Satallite, Active suspension, Silver over Black in color with beige. 68k on the clock. My 10th BMW in forty years.
Model Year: 2010
Engine: 550 Msport
Default +1
The first thing I would do is handle your power issues then go from there. Bad alternators can cause a lot of issues that are not there.
+1 It makes al kinds of things go crazy in these cars.
Old 03-22-2017, 05:56 PM
OSI550i's Avatar
I have done the right alignment with the dealer and they've checked everything and told me it was over tighten a bit ,however, they fixed it and everything looks okay.
Old 03-22-2017, 05:59 PM
OSI550i's Avatar
After the change of the alternator, I have still one problem that is driving me crazy and I wish to solve it! Which is linked in this link !
The issue not the rpm but it's when I turn the car completely off and try to crank it again (especially when it's hot) it won't start easily as you will see in the video ! Did any one have this issue somehow?
Old 03-22-2017, 07:00 PM
Model Year: 05 530i
Engine: 3.0 M54
Is this a car you just bought recently? You have a lot of issues going on at one time.
It seems like your starter is going out. You can either rebuild it yourself or buy a reman. It seems like the starter is staying engaged after releasing the key.
Old 03-22-2017, 07:05 PM
OSI550i's Avatar
No it's not a new. I have had it for 3 years now. The rpm craziness is because i have installed the new MAF it will act like that but if i swap it with the old one it stays normal. However, the main issue is the start thing ! I hope it's what you mentioned because i am not sure what it is !
Old 03-23-2017, 04:12 AM
Model Year: 05 530i
Engine: 3.0 M54
If it is the MAF making it jump then the new one might be bad. Is the new one OE or aftermarket/OEM. If its aftermarket/OEM then get you an OE. That should correct it. If it is indeed and OE then you might have been sent a bad one or the wrong one.
