RPI scoop install
I finally bit the bullet and decided to get a RPI scoop.
However, do I have a different intake than normal? With out some major bending I cannot make it fit.
http://www.flickr.com/photos/traitorous8/5670713307/
http://www.flickr.com/photos/traitorous8/5671282186/
http://www.flickr.com/photos/traitorous8/5671282446/
The worst part is that it rubs right against the support. The is with the flat, main, portion of the body as flush (flush at the top but 5mm opening at the bottom) against the intake. The support prevents the scoop from mounting flush.
http://www.flickr.com/photos/traitorous8/5670714365/
Thankfully, Trinity called me back 18:15 on a Friday night (WOW!) but there wasn't much resolution other than to just bend it. The paint started flaking off when I did that.
My Ride: 14 550i
If you have the 550i, I'm guessing you do from your name it looks like the scoop isn't rounded like it is in the install instructions
Did you show Joe the pictures you're showing us? Ask him about the round bend.
Michael
Owner
Acute Performance
Michael
Owner
Acute Performance
Just adjust the bottom portion a bit as http://www.racepreci...ic.php?f=7&t=10
All is well now - I got over my fear of bending the support to make it fit. I'm used to Mercedes and Bosch parts that fit perfectly all the time. Made me spoiled.
All is well now:
http://www.flickr.com/photos/traitorous8/5671061227/http://www.flickr.com/photos/traitorous8/5671628302/
The only thing that makes me really nervous are the length of the self tapping screws... a size smaller would be better so that the ends don't protrude soooooooooo close to the radiator:
http://www.flickr.com/photos/traitorous8/5671628818/
socale39
09-05-2023 08:30 AM
SFx550i
04-14-2015 05:00 PM
