RPA pressure warning won't reset!
Hi All,
My puncture warning starting bonging at me (again) today. I have a slow puncture and have arranged to get the tyre replaced next week, so have been topping up the air when it starts to complain.
Today I topped up the air, went in to reset the RPA, but having completed the procedure it still says I have a puncture?! Usually the status would change to initializing.
Any ideas?
Andy
Any ideas?
Andy
My Ride: 2006 550i - Metallic Mystic Blue, Sport Package, STEPTRONIC Auto Transmission, Leather Interior, Power Front Seats w/Lumbar Support, Xeonon Head Lights (Angel Eyes), Park Distance Control (PDC), 6-CD Changer, Adaptive Head Light, SIRIUS Satellite Radio, Professional Radio, Premium Sound Package 13-Speakers Logic 7, Weather Band Radio, Voice Control (for Bluetooth Telephone Operatoin), 18" Run Flats, Rain-Sensing Wipers, Front/Rear Heated Seats, Flat Tire Monitor (FTM), Moonroof, Fold Down Rear Seats, Hardwired Valentine One
Originally Posted by AndyPandy' post='548040' date='Mar 20 2008, 09:23 AM
Hi All,
Any ideas?
Andy
Any ideas?
Andy
My Ride: G30 M550i
Model Year: 2018
When you have a slow leak and put air back in the tire, there should be no need to reset anything. Resetting is only needed when you decide to run with different pressures since the last reset (or you change wheels/tires...)
In other words, if the system is initialized while each tire is at 35psi (as an example), when one tire goes down due to a leak, you only need to put air back in that tire. The system will still be calibrated at 35psi all around so there is no need to do any resetting...
My Ride: G30 M550i
Model Year: 2018
Right, but when you mentioned that you were resetting it daily, I assumed you were resetting it daily. You simply don't need to do this each time you fill a tire that's low...
However, I took it to the dealer yesterday to get replaced, but, they won't have a tire replacement until Monday; so in the meantime.. I'm keeping it inflated.
Sorry; to clarify....
The car is telling me I have a puncture, when I fill the tyre back up with air the error doesn't go away, and the stealer says to initialize it as I mentioned earlier. My car doesn't have the pressure monitors, it monitors the tyre by the wheels' RPM, measured using the ABS sensors I believe. If one is travelling alot faster than the others, it alarms.
Either way, I left the car for a couple of hours, went back and tried again and it worked! No clue why it was refusing to initialize before as I did everything correctly (car at a standstill, ignition on etc.)
How would one go about rebooting a car....????![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
Andy
Andy
My Ride: G30 M550i
Model Year: 2018
Originally Posted by AndyPandy' post='548146' date='Mar 20 2008, 01:13 PM
How would one go about rebooting a car....???? ![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
Andy
Andy
http://forums.e60.net/index.php?showtopic=9488
Originally Posted by Rudy' post='548325' date='Mar 20 2008, 05:11 PM
Originally Posted by AndyPandy' post='548553' date='Mar 21 2008, 06:55 AM
Sadly not, perhaps the only option is to disconnect the battery for a short while.
Vman33
03-14-2022 04:43 AM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
