RPA
Hi,
I have activated RPA, but don't understand what its function is ?
Does it mean that I never need to check my tyre pressure manually as the RPA will tell me when/if I loose some pressure?
Or
Is it there to tell me that I have a flat in my Run Flats?
Thanks in advance.
Or
Thanks in advance.
Originally Posted by mesh' date='Oct 13 2005, 11:55 AM
Hi,
Or
Thanks in advance.
Or
Thanks in advance.
[snapback]183640[/snapback]
It works via the ABS sensors in the wheel. When a wheel loses pressure it actually starts to spin slightly faster and the electronics can calculate when the difference is enough to alarm you...
My Ride: 2005 525d Mystic Blue Business Line
I read in TIS that the RPA will warn you if the pressure drops by more than 30% of the reference. That is the difference of spinning speed between wheels becomes significant at this point.
avaneyck
09-23-2008 09:10 AM
