Roundel Metal Valve Stem Caps vs. Plastic
My Ride: 2008 550i, Jet Black, Natural Brown Leather, Dark Wood Trim, 6 sd MT, Sports Pkg., Comfort Access, Sunshades, Cold Weather Pkg., iPod & USB, Nav, Satellite Radio w/Logic7.
Several owners have told me their SA told them on the newer cars if your valve stems are black you can use the metal valve stem caps, yet if they are grey then you have to use plastic caps. The reason being they have changed the tire pressure monitoring on cars with grey valve stems and the metal caps would cause faulty readings. Something to do with the pressure readings reflecting back off the caps. However I checked my valve stems and they are grey and I have the metal Roundel caps on them... with no issues. Go figure.
Anyone else heard of know of this isuue?
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
The issue has nothing to do with faulty pressure readings. The grey valve stems used with the TPMS sensors are made of aluminum. The metal caps will react with the aluminum, corrode, and get stuck on the stems.
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
Would be interested in knowing where you got that information. I would like to educate the two SA that told me it had to do with the computerized pressure monitoring system.
This article alludes to the corrosion problem, but specifically references the valve body, rather than the screw on cap. This article alludes to both the corrosion issue and another issue closer to what your SA references. Here's one more link as well.
My Ride: 535i 6-speed
For some reason, I feel compelled to ask the question: "What have we come to...when our cars take issue with which valve stem cap we use..."
My Ride: 2008 535xiT (E61)
Black Sapphire / Black Leather / bamboo.
Steptronic, Full Aero Kit, 35% Tints. 18" Run Flats.
All the goodies short of Active Cruise, Comfort Access and the safty options.
2002 BMW R1150R. Red, Corbin, PIAAs, Fiamm,
Originally Posted by Allen' post='550960' date='Mar 26 2008, 07:55 AM
For some reason, I feel compelled to ask the question: "What have we come to...when our cars take issue with which valve stem cap we use..." ![Roll Eyes (Sarcastic)](https://5series.net/forums/images/smilies/imported/rolleyes.gif)
![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
My Ride: 2008 BMW 550i Sport
Carbon Black Metallic/Cream Beige
Manny tranny and other stuff
Recently gone, but never forgotten:
2005 Ford Mustang GT (hence the name)
Torch Red/Crimson
Manny tranny and every option available for that year
2002 Chrysler 300M Special
Brilliant Black/Light Taupe/Dark Slate
Autostick and goo-gobs of neat features that I will sorely miss
Originally Posted by iversonm' post='550952' date='Mar 26 2008, 06:20 AM
Researching this further, it appears that both your SA and I am correct. Corrosion is a problem with the aluminum stem. However, a metal cap can interfere with the sensors ability to transmit. It appears that the valve stem acts as an antenna for the radio signal.
Originally Posted by GT Premi' post='550972' date='Mar 26 2008, 09:02 AM
I'm glad you did some research, otherwise I would've been compelled to ask you how you suppose manufacturers can get away with using iron blocks and aluminum heads on their engines.
(And, no, that's not the purpose of a head gasket.)
At least the E60 as aluminum hubs.
![Cool](https://5series.net/forums/images/smilies/cool.gif)
![Talking](https://5series.net/forums/images/icons/icon10.gif)
