Rough Idle
Old 11-25-2009, 06:14 AM
Migo's Avatar
Hey guys, been great so far here. I noticed when my car idles at a stop sign or red light, I'm getting really rough idles. Now I've never encountered a stall or rough start in the morning. But I figured for the reputation of a BMW this vibration shouldn't be happening. Just to clean things up. No warranty remaining and just picked up the car last week. I've read in other forums that changing the idle level has fixed this, and others saying to throw some top notch premium gasoline in and run it for a bit.
What are you thoughts or experiences?
Thanks
Old 11-25-2009, 07:31 AM
vlad_b's Avatar
My Ride: 2005 BMW 545i Sport Package, Jet Black M166 OEM Wheels M5 Style Body kit RPI Scoop BMC Air Filter Valentine One Radar Detector 35% tint all around
gasoline helped me a lot along with fuel additives. I noticed at winter the idle is rougher especially on cold start.
What car do you have?
Old 11-25-2009, 07:46 AM
Migo's Avatar
So you just used a different type of gas? I have an 06 530i. What kinda additives did you look at?
Old 11-25-2009, 08:11 AM
vlad_b's Avatar
i started using shell instead of chevron - and noticed that engine is smoother now. as for additives - i don't remember (bmw indy shop near me sells them). something like ""44K"..
by the way, when i had a car with inline 6 (e39) i never experienced rough idle. I thought it's just v8 engines, but seems like not
Old 11-25-2009, 08:16 AM
bigbadbull's Avatar
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
Do you have a pinging noise with cold starts?
Search on the N52 lifter issues
Old 11-25-2009, 08:17 AM
Migo's Avatar
Thanks...BG 44k?
Old 11-25-2009, 08:18 AM
Migo's Avatar
No Noise...only when i'm idling at a light it bounces around 500rpm. I lightly tap the gas and shes golden.
Old 11-25-2009, 08:21 AM
vlad_b's Avatar
Originally Posted by Migo' post='1062479' date='Nov 25 2009, 01:17 PM
Thanks...BG 44k?
yes that's right. if you use - make sure you have a full tank
Old 11-25-2009, 08:22 AM
Migo's Avatar
Ok i'm planing on going to Shell to use 93 octane and then throw this bottle in there? Correct?
Old 11-25-2009, 08:30 AM
vlad_b's Avatar
that's what i did. helped me to reduce rough idle at least in half. sometimes i don't feel it at all
but don't expect it to happen right away - it takes time (may be couple tanks) to notice the difference.
I hope it helps you too
Quick Reply: Rough Idle
