5Series.net - Forums
-   -   Rough Idle (https://5series.net/forums/e60-discussion-2/rough-idle-10186/)
realtyman Apr 26, 2005 06:55 PM
Last night I started my car and immediately noticed a rough idle. :huh: Also, the steering wheel didn't go down and several of the buttons didn't operate (seat heaters, sport button, more...). :( I figured this was a good time to try the old "three finger salute" (reboot). This was the first time that I tried it. The steering wheel went back down to normal position, the buttons started working and the idle smoothed right out. :thumbsup:
This morning everything is working but the idle was still rough and didn't smooth out once driving. I rebooted again and the engine smoothed out for a few minutes, the back to rough (feels like a plug wire was pulled). :angry: After several reboots I called the dealer. I was scheduled to go in May 9 for regular service and aux input but they were willing to take me today given the new issue. Of course I couldn't make it so I've got an early trip to the dealer tomorrow AM.
Car has 21K miles.
Has this happened to anyone here yet? Any thoughts??
Rudy Apr 26, 2005 08:16 PM
It hasn't happened to me -- I don't know if that helps you or not...
gabman Apr 27, 2005 02:27 AM
Same thing happened to me on my 2004 just after I took delivery in March 2005.
The dealer adjusted the idle and problem seemed to go away. A few weeks later
I developed a major oil leak that resulted in an engine replacement.
Problem has not come up again with new engine.
realtyman Apr 27, 2005 08:28 AM
[snapback]120683[/snapback]
I hope it's not that bad.
At least they gave me a 5 as a loaner (525i).
daydok Apr 27, 2005 09:36 AM
..."I figured this was a good time to try the old "three finger salute" (reboot). This was the first time that I tried it. The steering wheel went back down to normal position, the buttons started working and the idle smoothed right out."...
is this just restarting the car, or are you talking of something else?
i was thinking ctrl-alt-del when you say 3 finger salute, but not quite sure what you mean for the e60? :huh:
thanks,
daydok
realtyman Apr 27, 2005 10:16 AM
i was thinking ctrl-alt-del when you say 3 finger salute, but not quite sure what you mean for the e60?? :huh:
thanks,
daydok
[snapback]120843[/snapback]
Basically yes, ctrl-alt-del.
In the case of the e60 it is radio button and the eject button on the cd player and the eject button on the Nav at the same time.
Bark41 Apr 27, 2005 11:10 AM
I added a B&B exhaust and I get a little rough idle when the motor is cold and I also get a little power surge also when it is cold!!!! But that is it. I still love my B&B!!
DannyZBMW Apr 27, 2005 11:23 AM
Hi,
There is a Technical Service Bulletin that is think covers this:
SI B 11 02 05 (Engine)
DZ
realtyman Apr 27, 2005 11:52 AM
[snapback]120874[/snapback]
This is definitely Not a B&B issue. Still ove mine too. :wub:
Originally Posted by DannyZBMW' date='Apr 27 2005, 02:23 PM
Hi,
DZ
[snapback]120878[/snapback]
Any description or a link to what it is?
I will forward it to my SA. Thanks.
DannyZBMW Apr 27, 2005 12:33 PM
Hi,
Here is what the documents cover:
Cause:
Incorrect tolerances and geometry of Valvetronic intermediate levers are causing uneven cylinder filling during the transitional cold start period (60 seconds after the engine has been started) when the Valvetronic system is switching from the initial 6mm to a minimum of 0.3/0.8 mm valve lift.
Correction:
On a customer compaint basis, and after performing diagnostic procedures per SI B 11 02 05, replace the Valvetronic intermediate levers.
They should be able to pull up the document with the parts/steps needed.
Danny Z
