Right reverse light malfunction
Old Mar 7, 2013 | 06:47 AM
ccrellin's Avatar
Default Right reverse light malfunction
I am assuming it is burnt out so I got some replacements but is this an easy thing to do? I assume there is a panel in the trunk with a few screws that will give me access to the light bulbs.
Am I close? Anything I need to know before I tackle this hopefully 5 min job?
Thanks!
Old Mar 7, 2013 | 06:59 AM
pcy's Avatar
pcy
Yes, it's very easy to remove the panel. IIRC, 4 nuts to remove and the panel that holds the bulbs comes out.
Old Mar 8, 2013 | 06:17 AM
NoQuarter's Avatar
Engine: N54
May not be just the bulb.
Be sure to unplug the big wire harness plug that goes to the whole light assembly and inspect inside the plug for burnt/melted wires and spade terminals.
This is not hard to do - just unplug it and look at it. You will know immeadiately if something looks wrong.
BLACK_PRINCE54915
May 8, 2019 02:45 AM
RussHamel73
Jun 27, 2015 12:20 PM
stormhammer
Jun 18, 2015 07:25 AM
seven11
Jun 12, 2015 03:22 PM
RussHamel73
Jun 3, 2015 08:24 AM
