Reversing with Steptronic
Old 11-13-2006, 03:30 AM
juliann's Avatar
My Ride: 535d Sport Tourer - E34 M5 Race Car
Hi,
Wondering if I have a steptronic gearbox problem here :
When facing down a hill, if I select reverse and take my feet off both pedals, the car rolls forward - no resistance. I'm sure this isn't right and that it should not be able to roll forward.
Anyone else experienced this ?
thanks
Old 11-13-2006, 03:41 AM
dlevi67's Avatar
Depends on how steep the hill is. Simplifying the matter rather brutally, the engine at idle will only generate a certain amount of force (torque). If that is less than the force of gravity pulling you down the hill, then you will go down.
Bear in mind that on a 535d reverse is a taller gear than 1st, so if the car is pointing "up" the hill and you have 1st engaged it may stay there...
That's assuming the engine is on. If it's off, differently from a manual car, on an automatic there is very little resistance to movement with the engine switched off when "in gear", as there is no solid link between the wheels and the engine. That's why autos have both Neutral and Park positions.
In summary - it does not sound like a problem with the gearbox.
Old 11-14-2006, 12:13 AM
pinguhk's Avatar
My Ride: Mini Cooper
he right but you can alway push the petor a bit harder
Old 11-14-2006, 03:03 AM
juliann's Avatar
Thanks for that. I'm sure something has changed though as the hill in question is my driveway and I'm sure I never used to roll forward - maybe just my mind playing tricks on me !
Old 11-14-2006, 09:21 AM
dlevi67's Avatar
Maybe. Or maybe you have positioned the car in the past at a point where the incline is slightly less, and just enough to keep the car stationary. Or - if you have a new car - parts including transmission parts are still working themselves "loose" (not in the sense of clonking on the road; just ran in and smoother)
JeremyR
02-06-2016 10:23 AM
DJ JoeyG
11-09-2015 07:24 AM
Alan111
09-09-2015 07:42 AM
Maini
08-13-2015 03:40 PM
Bank$hot530
07-12-2015 04:36 PM
Quick Reply: Reversing with Steptronic
