Retrofit E60 M5 meter cluster to non-M5
Guys, have anybody ever done this before? It just coming to my head for this mod.. Need advice from you guys.. Thanks..:D
You can swap and the tach should be a direct swap over, but the speedo from 0 - 120 kph is in 20 kph increments, and then from 120 - 330 is in 30 kph increments. You have to find a way to code your old cluster (with the M5 plastic face plates and bulbs) to change speed increments above 120.
