Restraint Systems Faulty! Help.
Old 05-08-2004, 09:48 PM
Bunbun's Avatar
Angry
Hi Kiran
Mine has the same problem, restraint faulty message pops up everytime I start the car. Took it in twice, first time they tried to "reprogram" the "system" (whatever that means). When that didn't work, they changed a door "computer module" on the passenger side (whatever that is). And that failed again on the next day, restraint message came back on as before.
Now I kinda gave up and learned to ignore the fact that I have to press the IDrive menu button everyday I start the car to make the message go away.
If your tech found the cure, can u pls kindly share the solution with me?
Million thx
Bunbun.
Old 05-09-2004, 05:20 AM
kiran's Avatar
Originally Posted by NickP' date='May 8 2004, 05:11 PM
Did they give you a 3 loaner?
No, they offered one for this weekend but didn't want a 3er, so i said i would wait till monday when their 5 loaner came in.
Cheers.
Kiran
Old 05-15-2004, 05:54 AM
kiran's Avatar
Arrow
Hi guys,
I Have just recieved my car back from my dealer and the problem SEEMS to be cured. (But still waiting to see if it will come up again)
I asked for a report on what was done:
Invoice to Warranty Claims
Description Nett ?'s
---Labour---
Road Test 25.48
Interrogate Fault Memory 25.48
R/R glove box 12.74
R/R both front door Trim Panels 63.70
R/R Body Control Module 50.96
R/R trim panels both door pillars 25.48
Carry Out opps Byte Flight test & signal test 38.22
Replaced airbag control module with gateway control module 25.48
Programming/encoding control units (with CAS) 44.59
Total Labour Charges 312.13
---Parts---
Control Uni 285.96
Total Parts 285.96
Invoice Total 598.09
There are Part/OP codes associated with each of these so if you want these also then i can type them up.
Can anyone explain any of these items in any more detail?
Cheers.
Kiran
Old 05-15-2004, 08:51 AM
jonboy's Avatar
kiran
good luck I hope that sorts it
Jonboy
Old 05-15-2004, 03:46 PM
Ovidiu's Avatar
Originally Posted by kiran' date='May 15 2004, 07:54 AM
Hi guys,
I suggest you install a firewall or an anti-virus or something before pluging your car back in to the matrix!
predshaw
13
11-22-2021 05:58 AM
rkilpa
08-04-2015 06:14 PM
bifajv
07-30-2015 05:37 PM
zukgod1
07-14-2015 10:19 PM
Bank$hot530
07-12-2015 04:36 PM
Quick Reply: Restraint Systems Faulty! Help.
