Restraint System Fault After Steering Wheel Change
Hi
I recently swapped my steering wheel as I sent it away to be retrimmed. After refitting everything the car worked fine with no problems, 30 mins into driving I got the dreaded Restraint Systems Failure fault, I recently changed the battrey so it can't be a wornout battrey and also fitted a passenger seat occupancy sensor bypass unit to check that but after resetting the fault on INPA the fault returns after restarting the car, I am assuming its something i've done when refitting the airbag in the steering wheel either that or when I reconnected the battrey.
Any help would be greatly appreciated.
Cheers
Cheers
