Residue heat function
My Ride: E60 530i
Engine: M54
I would like to know how the feature "Residue heat" work in our E60 ? Which model year of our E60 has/have this feature ?
Thanks,
Thanks,
My Ride: 2008 BMW 550i Sport Carbon Metallic / Black
Traded in:
2005 BMW 545i Sport Black/Black
My 05 545i Sport has this feature... i live in Texas so this is used about once a year. I believe "manual says the engine has to be at operating temp, full battery voltage, and within 15 min of turning off engine." This uses the heat generated by the engine to heat the cabin for short periods of time (~15min) when the car is off. (EX. running into the store..)
My Ride: E60 530i
Engine: M54
Thanks for the prompt response. Does this feature has anything to do with the water pump in our E60 ? As far as I know, E60 water pump is driven by the accessories belt. So it runs when engine is running to circulate the coolant within engine and radiator.
Thanks,
Thanks,
Model Year: 2010
The first year E60 had "Residual Heat" for 2004. The previous-gen E39 5-series has it too. This mode uses the blower fan only. The water pump is not utilized. From the owner's manual, "Residual heat mode".
Residual heat
The heat stored in the engine is used to heat the passenger compartment, e.g. while stopped at a school to pick up a child.
The function can be switched on when the following conditions are met:
- up to 15 minutes after switching off the engine
- with engine at operating temperature
- with sufficient battery voltage
- at an outside temperature below 77F / 25C
The LED lights up when the function is switched on.
From radio readiness the interior temperature, the air volume and the air distribution can be set.
Residual heat
My Ride: E60 530i
Engine: M54
Residual heat
Residual heat
Thanks,
My Ride: E60 530i
Engine: M54
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
The only noise is the blower motor. Near the end of the 15 minute timeframe, the "warm" air becomes cooler and cooler so the water pump can not be involved. Use of the water pump would suck even more life out of the battery.
My Ride: E60 530i
Engine: M54
Thanks,
Model Year: 2012
I believe yes, otherwise there would be more heat available.
