Reset TPMS?
Old Dec 7, 2007 | 06:56 AM
Heelsonwheels's Avatar
Finally had my snows mounted today Dunlop M3 3D 245/40/18 x4 as per tirerack on the oem staggered 124's.
Anyway, half way to work the Flat tire monitor goes on; Can someone post the sequence to reset it.
No time to go back for them to do it.
BTW... ride/handling is nice and don't look half bad.
Thanks.
Old Dec 7, 2007 | 07:16 AM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
Thanks.
Assuming the tire place properly installed the sensors, go into iDrive by pressing the knob down. Scroll down and you'll see something like Tires/Vehicle. In there is the TPMS system. With the car started but in Park, hit the Reset option then drive. It will take a few minutes to reset. Probably best to do it someplace where you can get on a long stretch of open road like the interstate. Stop and go city traffic will take longer to reset.
Old Dec 7, 2007 | 10:12 AM
Thanks, I got it. With the car started and in Park. I pressed the idrive and then went to 'vehicle settings', then found 'FTM' (flat tire monitor); and reset it from there. Actually it was pretty easy.
Old Dec 7, 2007 | 10:20 AM
Veight's Avatar
Thanks.
I had a similar issue. Last weekend in advance of our first snow, I put my four original equipment 124's with the std 18" bridgestone re050 runflats on and removed my 166's with the 19" ps2's. Well I finally drove the car on Thursday when the temp was like 10 degrees and instantly as i drove away from my house, the TPM went off on all four tires. I realized that these tires have been sitting since spring and I never filled them with air. And when its cold out you have a hard time finding a working air pump at a gas station. Went to 3 places before I found a working one. When i restarted the car, the TPM was on and all four tires appeared green, so it seems to reset itself. My tires were down to 24 lbs so I don't think I did too much damage since they are runflats.
alexbaldy
Sep 28, 2015 12:28 PM
05Mdriver
Aug 24, 2015 05:41 AM
TMK
E60 M5 Discussion
Aug 18, 2015 01:32 PM
rkilpa
Aug 4, 2015 06:14 PM
Hyper_545i
Jul 1, 2015 05:07 PM
