replace rear tires with hankook v12 now vibration!!! help
I replaced the rear tires on my 08 550 with hankook v12 275/30/19 after reading some good reviews on it. The front tires are still stock continental sport contact two 245/35/19 with 50% tread. The tires were mounted and balanced at a well know tire shop with GSP 9700 hunter machine but now I'm having vibration around 70 mph mainly feeling it on the seats. I went back couple days later to have it re-balance but the same problem occurs. I call the place where I got the hankook from and they told me the problem is due to the mismatching tires and the continental front is much softer then the hankook rear.
I just want to ask you guys who have same setup having this problem? or take it to another tire shop to balance? They both summer tire so I didn't think it would matter.
Thanks for the help
Thanks for the help
My Ride: 2005 E61 525d M-Sport, Titanium Silver, Black Dakota Leather, Media Pack, Sun Protection Glass, M6 Staggered Alloys, ACS Rear Diffuser, EBC Green Stuff Brake Pads, I-Pod Interface. Rear Aux Power DIY, LCI Rear Lights, Extended interior lights - doors and footwells, LED licence plate lights.
Thanks for the help
Thanks for the help
its not the tires or the wheels you might need a hub ring depending on what wheels you got.. the wheel center hub on a 5 series is normally 72.6 mm ( if i'm not mistaken) the wheels you got probably has a bigger... double check and good luck
I did check the direction and it's mounted correct. Had all four tires balanced when they were mounting the wear and went back to get all four rebalanced but the problem still there. The vibration is usually at 60-80 miles. Mainly the seat is vibration the steering wheels seen to be fine.
I have stock Mtech 19" wheels.
Let us know how it all works out for you.
howcome you didnt do all 4? Im just asking, cause if you didnt have the vibration before you changed the two rears then obviously it must be cause they are mismatched. I mean that seems like the logical answer being that they were mounted and balanced correctly and the wheels are not bent.. Your talking about stock 172's right?
My Ride: 05 545 BLK/BLK
Model Year: 2005
WOW... I bought the same rear tires for my car and I have the vibration around 70 as well. I was thinking that they weren't balanced correctly. I didn't have the virbration before the new tires either.
