replace coil springs or not at 175,000 miles?
My Ride: 530i
I'm replacing everything, upper and lower control arms, whole tie rod assemblies, struts and mounts, took everything apart and all of these components' life has ended. My coil springs are original and I don't really know if there's a way to test them. I'd hate to throw money away if they don't need replacement, and everywhere I'm looking, only lowering coil spring sets are being sold, and I don't want to lower my car. What's the general consensus?
My Ride: Stock 2004 BMW 525i
My Ride: 530i
My Ride: 530i
Engine: M54
OP, springs don't 'wear out' like the other stuff you're replacing. If they're not broken, rusted, etc, reuse them. The H&R springs on my E30 are over 20 years old and they're still perfectly OK.
![Smile](https://5series.net/forums/images/icons/icon7.gif)
you can, but bolting in a new arm is so much easier. plus, every time you remove and press a new bushing, you are actually removing aluminum material from the arm. I think BMW states that it should only be done once, after that you must replace the arm. OP, springs don't 'wear out' like the other stuff you're replacing. If they're not broken, rusted, etc, reuse them. The H&R springs on my E30 are over 20 years old and they're still perfectly OK.
Gregg
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
I think they wear out like other suspension components. At your milage they been compresses gazillions times and wound not work as they supposed to. What about the coilover? Like KW variant?
That is in my soon to do list.
My Ride: 530i
Tex, didn't take in a harsh way, just thought it's just easier to replace the whole control arm..I have no idea how take out the old ball joints, and I don't have access to a press to press in new ones and new bushings. Everywhere I read, everyone just replaces control arms.
As far as springs, I've read both ways, that springs are good forever, unless they're rusted or broken...or that they should be replaced after so long...I would tend to agree with the latter, I'd like to get a set of new stock springs, just for the heck of it, to refresh the whole suspension, plus at 175,000 miles with original struts, these strings took a lot of beating. Thing is, I can't find a set of stock height springs, everyone I'm looking, they're lowering. I guess I'll just reuse mine.
My Ride: BMW
You can always buy them from a dealer brand new (BUYBMWPARTS.COM) or other online stores.
Another is to look for them i salvage yards, but I'm a bit reluctant to get these kind of parts from salvage.
You can return the shock absorbers you ordered and get a single stage KW coilover which you can adjust to the original height.
If it were up to me and my car had that kind of mileage, I would replace the springs. I am sure if you look at a brand new spring, and measure it, it will be taller than the spring you have.
