Removing rear wheels
Old Jun 11, 2009 | 05:55 PM
superbri's Avatar
Okay I feel like an idiot for even asking this but is there a trick to removing the rear wheels. Front wheels came off effortlessly, removed all the lugs and rear still wont come off!
Old Jun 11, 2009 | 05:59 PM
CWS530's Avatar
Put the lugs back on, just not tightly, then lower the car. It should break the wheel loose from the hub. If not, start the car and move it back and forth a bit, then lift it back up, pull the lugs and see if you can pull off the wheels. If not, pull the lugs, lie on your back, and kick the sh*t out of the sidewalls. Put some anti-seize on there to avoid this the next time.
Old Jun 11, 2009 | 06:03 PM
Krozi's Avatar
Ah the words of wisdom
Old Jun 12, 2009 | 07:44 AM
CWS530's Avatar
Sometimes subtlety is overrated.
Old Jun 12, 2009 | 07:49 AM
theXman's Avatar
My Ride: 2004 530i
or try using one of those hammers with a rubber head and hit it around the sidewall carefully.
Old Jun 12, 2009 | 08:07 AM
Brit_in_NJ's Avatar
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather. Mods: Carbon filter removed. M5 iDrive knob. Umnitza license plate LEDs. MP3 40% 3M tint ACS Anti-Roll(sway) bars RPI Scoop G-tech Pro RR CF Roundels CF Wheel caps
Rubber Mallet
Old Jun 12, 2009 | 09:35 AM
Ricracing's Avatar
Originally Posted by Brit_in_NJ' post='909214' date='Jun 12 2009, 07:07 PM
Rubber Mallet
No, the boot it the correct tool.
Just don't miss the wheel nor have it on jacks too high.
Fenders are costly and if the car drops down, the hell is loose.
Old Jun 12, 2009 | 11:24 AM
pukka's Avatar
My Ride: 2008 535i: (8/07 Build) Metallic Bronze, Beige NASCA Leather, Ventilated Seats, Sport Pkg, Cold Wxr Pkg, Logic-7 Sound, HUD, Night Vision, PDC, Split Rear Seats, NAV, Premium Pkg, Comfort Access, HD Radio, Sport Auto Trans Current mods: M-Aero Kit, JB4, Motorcepts 6000k HID Foglamps Umnitza ICE-Lite 10w LED 6000k AE's 1992 Camaro RS: Fully Restored w/Custom Interior, 5.0L V8, T-tops, OEM Z28 Foglamps, Inst Cluster, & Spoiler, Custom Sound, Too many engine mods to list
I agree with using a rubber mallot - just don't stand too close or you can pull a "stooge" move due to the physics of rubber bouncing off of rubber.
You should also disengage the parking brake.
Old Jun 12, 2009 | 11:33 AM
fabolous531's Avatar
My Ride: 08' 550i
yes definately!... kick the shyt out of it!..lol...i was too frustrated when i had to take off the wheel on my 3series...then the AAA guy jacked it up and start kicking it i thaught he got pissed off at it lol
Old Jun 12, 2009 | 01:36 PM
sleeper50's Avatar
My Ride: 2006 Titanium Silver 550i, with all the bells and whistles!!
giv er a boot!
But a carefully placed and properly weighted boot! Galvanic corrosion between the hub and the alloy rim. smear some white lithium grease on the hub before you put your wheels back on.
