Removing BMWs fancy jubilee clips
Has anybody got any tips regarding the removal of the "continuous ring" type jubilee clips that BMW are now using, without damaging any of the relevant hoses? I'm not sure, but I think they may be called "anti-tamper jubilee clips".
Originally Posted by Howitzer' post='783357' date='Feb 2 2009, 08:41 PM
HUH?
So, to sum up, unless someone can explain otherwise, it would appear that the said hoses must have been fitted with half a coupling at each end, using machined rings.
Originally Posted by Howitzer' post='783415' date='Feb 2 2009, 10:04 PM
I see. Knowing BMW, they made it so you'd have to spend money to fix something instead of a convenient, easy-to-use method with a DIY.
Howitzer - here you go - and just look at the price!!!!
http://www.autopartswarehouse.com/popup.ph...zZQ==&text=
http://www.autopartswarehouse.com/search/?...4294965333+5607
TroyE60
05-30-2019 05:01 PM
chadillac2000
42
09-13-2017 11:15 AM
