Remote wire for amp in boot for BMW E60
Hi,
I am looking to set up an amp install for my 2003 BMW E60 520i.
I can't seem to find a fuse I can use that turns off when the car turns off.
Could I have some help on the right fuse or an alternative place for the remote?
I've attached pictures.
http://s30.postimg.org/51dgia7sh/photo_bm.jpg
http://s29.postimg.org/70p0cl3hz/photo_bm2.jpg
The cigarette lighters turn on/off with ignition if I remember correctly. Not quite in the right place but that's at least an option. Check it out
The ones on the rear of the center console (for the rear seats) are easy to get to. The whole panel that they are on pulls out from the bottom
My Ride: 2006 BMW 530xi 6MT
Engine: N52
What radio do you have now?
Is there already an amp located in the left fender area in the trunk?
Like this one (which isn't hooked up): http://i94.photobucket.com/albums/l9...anwar/boot.jpg
My Ride: 04 545i sport, stick, L7, sat, nav. Charcoal/ runflat/ cdv delete.
Suede headliner/ trunk, 3 way front speakers, four 8" subs in rear shelf, ACM, iPod dock in ash tray using gateway 500 with MP3 text and video on screen, MRTM aluminum pedals/ door pins, 10 farad cap, sound processor, line conditioner, 2 amps ( 4x100 and 2x200)
Check the green/white wire shown in the pic. That should be the cigarette lighter circuit, high amperage and ignition key controlled. It's the safest easiest ignition signal to grab on your car. It also should have it's fuse in that fuse box if you trace it down or check the number on the chart.
Engine: N52
You might use a meter on these rear fuses with the car off and on:
F61 - 20A - front cigar lighter
F80 - 30A - amplifier (maybe this is switched here?)
F82 - 20A - rear cigar lighter
These are correct for E60 cars up to 9/2005.
Get your meter out and see how these react with the car on/off and the radio mute/unmute.
SFx550i
Apr 14, 2015 05:00 PM
BYS2
Mar 24, 2015 03:13 AM
