Remote Key
I just wonder if you ever encountered this issue:
I previously was able to open my car from quite a distance (30m or so) with my remote keys. Starting two weeks ago, I'm just able to open my car no more than 5m away; and this happens with both keys (which means it's not some kind of key discharge issue): any hints ?
My e 39 and X5 both unlocked from a long distance , but the new car only works within 10 feet or so, ask Rudy he helped me on this question.
Good Luck
Good Luck
My Ride: 2004 545 SMG + Sports Black with Truffle brown interior
I have noticed the same issue. I have found however that if you hold the button on the FOB down a little longer it will transmitt from a little farther away. Still it does not compare to the last car I had that would work from over 60' away.
My Ride: 2009 550i sports, Nav, logic Best E60 yet
2004 545i, sports pkg, logic 7 steptronic, rear shade,orient blue with beige interior, blue tooth enabled Razer Phone. 2004 X5 3.0, sports pkg, stepronic, summer pkg. imola red.
2006 Mini Cooper S, manual, sports, prem pkg, nav and kitchen sink.
Please let me know if you get this resolved.
My Ride: 535d M-Sport '06 Plate - Carbon Black - Black Leather - Pro Sat Nav - Logic 7 - HUD - Bluetooth - Privacy Glass - 172M 19" Alloys - Heated Seats - PDC - Adaptive Headlights - Extended Voice Control - Paintshield Extended - M5 Boot Finisher - Bright White LED Internal Lighting - Dension Gateway 500 Ipod/USB/Aux Integration
My Ride: 2008 535i, 6spd mtx, Monaco Blue w/Beige interior. Sport, Preimum, Logic 7/HD/I-Pod/USB, Nav sys, rear sunshade, HUD, PDC, Split seats,
Originally Posted by MarcsOnFire' post='505856' date='Dec 12 2007, 01:23 AM
LOL...
I have noticed that the range on my remote seems to have diminished as well. Let us know what the dealer has to say about it. As far as the Clarkson trick, this does indeed work. I first heard about it in the early 90's. Uses your body as an antenna increasing range.
I had the same problem on my 550 and had my key replaced with a new one, as one key did work better than the other. Same thing. it really did not work any better than the old key, so took it in and they replaced the antenna for the remote. Voila, problem solved. Now I can unlock the car before I get to the garage.
The service advisor did tell me that the antenna was in the back.
