Remote Car Key Signal Shorten After Rear Windows Replacement?
I had to replace my E60 back rear window last week :'( and after installation I notice that I have to stand right next to the driver door for the lock/unlock button on my car key to work. If I stand in the back of the car (trunk) or on the right hand passenger side the lock/unlock button won't work due to lack of signal(?)
Did the installer forgot to plug some thing (atenna cables) back?
My Ride: G30 M550i
Model Year: 2018
Originally Posted by freed0m' post='342897' date='Oct 8 2006, 06:01 PM
I had to replace my rear windows last week :'( and after installation I notice that I have to stand right next to the driver door for the lock/unlock button on my car key to work. If I stand in the back of the car (trunk) or on the right hand passenger side the lock/unlock button won't work due to lack of signal(?)
You are right, rear window...
Originally Posted by Rudy' post='342951' date='Oct 8 2006, 06:03 PM
Are you talking about the rear window (not plural) or the windows in the rear doors?
My Ride: G30 M550i
Model Year: 2018
Well, the rear window aerial is used for the reception of the remote unlock signal so yes, it's likely that they didn't hook it up properly (or there is a problem with the embedded antenna itself in the window.)
Do you get good radio reception? Was the window an OEM one or something else?
Good point Rudy... The replacement window should be OEM, I'll check the radio reception and confirm with the installer tomorrow. Thanks so much for the recommendation.
