Recommended Tire Pressure
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
Originally Posted by JDN' date='Oct 4 2005, 03:14 PM
I run 36/44 all the time and am happy with that pressure.
[snapback]179321[/snapback]
I'm running the 29/35 pressures in my 2006 530i Sport (245/40 18") and have been for a few months. I noticed an immediate 2mpg decrease in fuel efficiency, but the car seems smoother over bumps.
Originally Posted by donv' date='Oct 4 2005, 02:41 PM
[quote name='cobradav' date='Oct 4 2005, 12:47 PM'][quote name='donv' date='Oct 4 2005, 11:37 AM'][quote name='nbarco' date='Oct 4 2005, 06:19 AM']I have a 2006 530i and the recommended tire pressure differs depending on speed and load.? For me the speed and load differs greatly, and changing tire pressures constantly would be a pain the rear end.? Is there any drawbacks to keeping the pressure set at the max which is 36 front and 44 rear.? It roughens the ride, but improves the fuel economy, at least I have been told.
Is this true??
Are there any handling drawbacks??
What exactly does the increased pressure do to accomodate higher speeds?
Is this true??
[snapback]179087[/snapback]
[snapback]179173[/snapback]
[/quote]Good reads, donv. Other than comfort, higher (within specs of course) seemed to be better from the reading I did. Any reference to center wear seemed to point to "over" inflation, which appears most of us would not do. Did you notice how well the Tire Rack article on tire inflation versus speed tracked with the BMW manual recommendations Das posted. Apparently alot more research in Europe due to the increased speeds that can be driven regularly in there (well at least Germany). I have started going to just under the max recommended pressures, although I run a light load generally. That is what I have done on other car/tire combos with great success, at least on the tire wear side.
[snapback]179245[/snapback]
[/quote]Yes, I did note the correspondence you mention. And, higher definitely is better given very fast driving. The pressures that BMW give exactly mirror the idea from the article that they are aimed at European fast-lane driving. And, I too am not near the maximums for in town driving. But, for the road, I will bring them up some after reading the article. As mentioned, I am at 34 [R] and 32 (F). What are you running exactly? I once put my pressures up to the BMW recommendation and found the ride uncomfortable in general.[snapback]179279[/snapback]
[/quote]My manual recommends 39R and 33F for max load/speed. I started at 32R/29F (low end spec), Ran that way for about 2000 miles. Went to 35R/31F, could not tell difference in ride as much as cornering (better turn in). Stayed that way for some time and only recently have gone to 37R/33F. Not enough road surfaces yet to tell much about comfort (need those speed bumps, don't you know), but normal drive ok so far. With sport pkg has always felt stiff but complient so no disappointment at all so far. For the Cabrio version on same tire/wheel they increase the min and max pressure recommendations by 7R/6F PSI so load is significant factor.
Originally Posted by cobradav' date='Oct 4 2005, 03:53 PM
[quote name='donv' date='Oct 4 2005, 02:41 PM'][quote name='cobradav' date='Oct 4 2005, 12:47 PM'][quote name='donv' date='Oct 4 2005, 11:37 AM'][quote name='nbarco' date='Oct 4 2005, 06:19 AM']I have a 2006 530i and the recommended tire pressure differs depending on speed and load.? For me the speed and load differs greatly, and changing tire pressures constantly would be a pain the rear end.? Is there any drawbacks to keeping the pressure set at the max which is 36 front and 44 rear.? It roughens the ride, but improves the fuel economy, at least I have been told.
Is this true??
Is this true??
[snapback]179342[/snapback]
[/quote]Thanks for the info cobradav. I may experiment a tad more.
My Ride: 2005 525i Titanium Silver Metalic and 2003 325xi Jet Black with the Premium Package in both cars.
I run 36/44 and the only real difference I feel is a harder ride but the handling is great, corners real nice and coming into highway curves at a decent rate of speed you feel comfort as opposed to feeling the G forces...... I am happy with the 36/44.......buts thats me.
My Ride: 2005 530i (Silver-Gray, Gray Lthr., Anthracite Maple) with Steptronic, Prem. Pkg., Logic 7, Xenons & Chrome factory wheels.
On my 2005 530i (non-SP), run 30 front & 35 rear with 2 persons and no luggage. Occasionally, have to drive on roads that are pretty bad (potholes, etc.) and hate a bone-jarring ride.
No doubt, higher tire pressure would improve handling but the loss in ride comfort is too high a price to pay.
Have never understood BMW's unequal (front-back) tire pressure recommendations, since there is a 50-50 weight distribution. Have been told that it has to do with handling.
Martin
Martin
My Ride: GONE BUT NOT FOGOTTEN : 530d SE Auto : Titanium Grey / Anthracite Leather, Poplar Trim, 18in 123 Style Alloys, Adaptive Bi-Xenons, Business Nav, Hi-Fi Speaker Package, Heated seats, Split-Fold Rear Seats
LR DISCO 3 HSE with everything (including 3 kids)
I had my car in for some work - including false RFT warnings - as part of that they must have reset all of my trye pressures.
I was running with 36F / 44R, but when it came back it had 32F / 36R.
These seem low loo me but I must admit the ride is a little better.
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires
2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades
ON ORDER
cheers
vern
