Rechargeable key FOB doesn't work
Old 08-21-2017, 11:02 PM
Terano69's Avatar
My Ride: E61 523i, 2005, LPG
Battery is fully charged. It's not a problem with charging the battery. Must be some sort of a module that doesn't recognize the key is being charged.
Last night I've used INPA to check Status actual key and the main key I use is Key no: 1. There's one thing I don't understand. There is a line "Key Locked" and it has a black dot. Does this have to be on or?
See print screen:
I've also checked all the fuses and they are all fine.
Old 08-22-2017, 12:41 AM
ianbmwe60's Avatar
My Ride: bmw e60 msport
Model Year: E60
Engine: 2.5
Black dots means it's activated.what exactly is your key not doing
Old 08-22-2017, 12:43 AM
Terano69's Avatar
I can't unlock my car with remote control. I have to use the plastic key or the metal key that is attached in the remote control.
I wrote a detailed explanation in the 1st tread.
Cheers
Old 08-22-2017, 02:02 AM
ianbmwe60's Avatar
Model Year: E60
Engine: 2.5
Well your problem than is the diversity ie antenna
Old 08-22-2017, 10:16 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
+1, was just about to post this also.
Old 08-28-2017, 02:36 PM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
i believe the "key locked" just means that the key is inserted into the ignition slot and locked into place.
Old 08-30-2017, 11:00 PM
Terano69's Avatar
Fixed
There were 2 things wrong:
1) Diversity antenna
2) The cable that comes to diversity antenna.
The problem was that I've tried with a new diversity already and it didn't work because the cable was also corroded. That's why it didn't work. When I opened it all over again I've noticed that cable contacts were completely corroded. I've cleaned them up and ordered a replacement diversity and ..... Thing works.
Thank you everyone for your help!
Old 09-01-2017, 01:00 AM
chris30o0's Avatar
My Ride: E60
Engine: 530d
Don't think it's a programming issue either.
Can you tell me how you got into that menu, though? Just curious.
Old 09-01-2017, 01:11 AM
Terano69's Avatar
Can't remember all the steps. If you open in INPA and then navigate a bit you're sooner or later see the Actual Key Status.
Hope this helps. If you can't find it let me know and I'll connect the cable again.
