Rear Windshield Rubber Seal Fix
Whats up guys i was wondering what i can do about this issue they all just start falling off any DIY'S any help would be appreciated? Heres the pictures so you guys can see
i found the seal from ECS Tuning but there is two different options one for vehicles without comfort glass, protective glazing, or safety glass and one for vehicles with comfort glass
http://www.ecstuning...xterior/Window/
My Ride: 530i
Engine: M54
DIY replacement
there you go, good luck mang!
IIRC, the 'comfort' glass is basically radiation blocking glass that has a rainbow color effect that's visible when looking at the glass from an angle, similar to the iridium coating OAKLEY puts on its sunglass lenses. You could always ask your dealer if you're not 100% positive.
DIY replacement
If your rear seal looks like that chances are the sunroof seal and front windshield top seal also needs replacing. I've started mine and I'll finish the front in the next days.
I ordered my replacement from ECS Tuning also however, I can't recall which one. I just went by the pics in their website and luckily it fit. Providing them with a VIN# shouldn't hurt. Install is very easily done, you should have no problem. I'm about to order my front windshield seals soon as they are now beginning to look like cookie crumbs.
they sure do bro once im done with the rear ill do the rest do you know how i can fix the noise from the moonroof not a wind noise like something sounds loose
My Ride: 2013 535i (White with Oyster Interior. Premium Package, Navigation, Technology Pacakge, Park Distance Control, and Rear View Camera)
What is the difference between vehicles with or without comfort glass. What is comfort glass?
There were a few repair threads out that just needs a small piece of felt. I recall the noise sounding like a metallic or clinging sound. The seal around the roof is also very easy to change and really makes a difference in the cabin sound. Mine looked very good by itself, but when I compared it to the new one the old seal was really hard but not cracking but still needed to be replaced.
