Rear Window Seal Replacement
Has anyone changed out there rear window seal on a 08 LCI ? A friend of mine has an 07 Pre- LCI and he did his and I've seen some on here make a post about it as well. I'm thinking everything I read about was pre LCI though. I am not sure if the the seals are the same or not. When I look at mine, I just can't tell if its glued in or not and if the glass has to be removed in order to get the new on back in. It would really suck to pull this thing and find out otherwise! I know on my old truck the front windshield had to come out in order to replace the seal because of the dried butyl and the fitment of the glass. The install guy said you would never get this back in on the truck without removing the glass...
I dont think theres a difference whether its lci or pre lci but there is an option for something called comfort glass. No glue needed and the glass does not need to be removed. Check out http://www.ecstuning.com , enter your vehicle info, click on the exterior category, then click on the window category.
My Ride: BMW 550i M Sport
Model Year: 2010
Engine: 4.8L V8
I need to do this too! I do have a pre-LCI, but I'm also afraid I won't be able to get the glass back in properly. How did your buddy do it on his '07 without removing the glass? Also a link to source the window seal at a good price, if anybody knows, would be great. Thanks.
I put a call into him but he hasn't called back yet. I remember him telling me it was very easy and there was no glue. I am going to search here too because I know I've seen a DIY for this. I just wasn't sure if there was a difference from pre and LCI. I found this wonderful DIY. WTF ? What kinda nonsense is this?
https://5series.net/forums/topic/124...1#entry1450710
I guess its SO easy they forgot to explain or post pics. I'm gonna go ahead and order the seal based on what I remember it must be a doable project and not too difficult. So I will post up some pics and a DIY to the original posting. Well. that is if it's so easy that I get a head of myself and forget to do it...
Ok according to my friend he said just pull out the old one. Left, top and right side all one piece. He didn't replace the bottom seal. Install the new seal by pressing it in place. Sounds like there is no need to clean as the channel should still ave soft / sticky butyl inside. Leave this in there. I'm going to check and see if there s a sall tube of butyl that can be purchased in case a litte more s needed. Recommend to start in one of the corners and secure the top then go dwn ether side. Use a fishbone or plastic tool instead of a screwdriver. I'll post up pic when I do this.
I found this great video on YouTube for the front which I will also do at the same time. It's a three series but I am sure it's the same process
Well you saw the video it is that easy!
- use a plastic scraper and...
- use a vacuum and vacuum the channel
- Use a rag and a spray cleaner (409,windex, etc) to wipe channel clean
- lay rubber on top of channel
- insert, use plastic scraper to help align and it is in.
![](https://5series.net/forums/public/style_emoticons/default/rolleyes.gif)
- use a plastic scraper and... http://www.youtube.c...w&feature=g-upl
Super, thanks for the update! What are your thoughts on the rear seal in regard to the sticky butyl that maybe left in the track? Did you have this? Should we remove it? Thats where I am just not sure if its excess or there for a reason, if its there at all. I actually haven't pulled mine yet so I don't know if its there.
Model Year: 2010
Engine: 4.8L V8
![Bashwall](https://5series.net/forums/images/smilies/imported/bashwall.gif)
Nate
Thanks for the write-up Tony. I will follow the directions given in the videos on the rear seal. My front seal looks good, it must have been replaced shortly before I purchased the CPO. It all sounds easy enough but I have tried a few things that members have said was EASY..PEASY and it was HARD AS HELL
so I guess we'll see. Can you tell me where you purchased the seal? Let me know how your install goes brotha.
Nate
Nate
