Rear Wheels have negative camber problems?
My Ride: 2005 545i
Cold Weather Package
Navigation and Logic7 Package
Sport Suspension Package
i have a 2005 545i with sport package and i blew a tire because i have negative cambers in the rear.. i just put 20" straggered rims and still doing it after allinement..has anyone tried to install a camber kit on the car or any other solutions?????
not sure about camber kits, but the oem sport package does cause a negative camber on their own, not sure if the 20"'s helped the situation any. What tire brand and size are you running? Are you running on the stock springs/suspension?
You could also try running a search using the upper right bar..GL and to the forums.
My Ride: 2005 545i
when i found out that the cambers were negative i had the stock 18' rims with the run flats... i didn't do any suspension work to the car completely factory. so when the rear passenger tire blew, that gave me a reason to get new rims. but still after an alinement tires bend in.. its not that bad, but i would like it straight don't want to go thought tire every 6 months... does any one 545i have camber problems and how long do there rear tires last?
thanks guys love the forum really helpful!!!
BMW does it on purpose for better handling through the turns. But going through tires in 6 months is pretty quick, do you rotate the tires?
My Ride: 2005 545i
i just got the car a month ago and this just happened... never got a chance to rotate them.. can you rotate the tires with staggered wheels?
and also how do you put your pictures on your signatures??
But now I am wondering if you could just ask an alignment shop to just set the camber to 0? I wonder how much you extra the tires would last, and also how much it would throw off the handling?
as for the pictures, click your screen name where it says "logged in as" at the top left. then click "edit signature" in the center. if you photo is in photobucket, copy and paste the IMG code
I have Staggered 20's on my 04 530. I just replaced me rear tires after almost 40k miles. The tires are Nitto Extreme, and I have to say they are the best tires i have had. Yes the rear camber caused my tires to wear on the inside of the tire. Maybe two inches in from the side. I ran about 32-33 psi. The reason i claim the tires is because I was driving down the highway and all of the sudden it sounded like something was flapping against the body. I thought, huh? maybe my seatbelt or something sticking out the door. NOPE it was a foot long strip of rubber that had been worn to the thread and then seperated. I cut it off and drove to the tire shop. New tire and all is well. Have about 44k miles on the fronts and plan on changing them next week. If the PSI is too high it can make a huge difference on how long they last. I am no expert but that has been my experience. Any other thoughts?
Also,
I am not nice to them either.
I will update my profile and you will see!
Also,
