Rear tire wear
My Ride: 2007 550i
2007 550i. Pulling tires off car to get wheels and inner fenders cleaned. Right rear tire has a groove on the inner face - edge of tire, one spot has the wire belting showing. These are stock staggered wheels with 275/35/18 tires. Not lowered. Tire man says it's because BMW puts negative camber in, but tire wear is perfect across the face of tire. Any ideas what would cause this?
+1 Rear tire tread wear can be uneven because of the independent rear suspension but are you saying the wear is more on the sidewall? If that's the case it's odd and should be inspected. And if only one tire is wearing oddly you should have the alignment checked - check that side rear strut too. Look for any signs of leaking that would indicate it's bad.
My Ride: G30 M550i
Model Year: 2018
My Ride: 2007 550i
We bought the car used a year ago with these tires on it, looked pretty darn new. They are not stock tires. Car has 48k miles - two sets of tires, they are pretty much worn out so I don't have any heartbreak about that. Just want to have a grasp before new tires get put on. Thanks for your responses. Will search about negative camber. I read this forum and have learned much.
My Ride: BMW
Yes, rear wheels have a -2.0 camber so it should wear the tires out on the insides more than the outside. If both rears look worn out on the inside equally, then it's normal. If not, have the alignment checked.
socale39
09-05-2023 08:30 AM
TexaZ3
05-06-2015 09:54 AM
DILLESTJAMZ
05-05-2015 12:56 PM
