So yesterday my car finally showed the passanger restarint malfunction code so i thought nothing of it because i was just gone get it fixed under the recall..but later that night when i went to use my rear defrost button my radio became staticky all of a sudden but the day before i used it everything was fine so im guessing because my car finally showed the passanger code that its causing the defrost button to interfere with my radio for some reason..i hope the dealer can fix this..anyone have this problem with their car when they got the error message
There may be a problem with the antenna elements in the rear window or possibly something wrong with the diversity amplifier located above the rear window (behind the headliner.)
Search the forums for a bunch more info! ;) |
thanks will look into in now
My 06 330 also hav that problem dealer said I hav to remove tint in order for them to check it out.
Also happened after passanger airbag recall |
yup, i had to have a new rear screen to cure this little problem
so i have to take my tints off and it should work again without a problem then after i get the recall fixed
My car had the same problem (as did my previous E39). Had to have the rear window replaced under warranty...
i had the tint for over a year without problems untill the passenger restreint warning came on so i hope its just that because my warrenty expired already and i dont want to pay for a new rear window..well see what happens when i go to open road on monday..thanks for the help
| All times are GMT -8. The time now is 06:55 AM. |
