Randomly dimming info. display in dash
Old Mar 24, 2009 | 10:15 AM
1BRACE's Avatar
I have had this problem happen a few times recently. The info display that sits inbetween the tach and speedo starts off on its regular bright orange, then the brightness steps down until very dim and then back to full brightness.
this has only happened a few times and totally at random while driving. anyone else experience something similar?
thanks
Old Mar 24, 2009 | 10:20 AM
EBMCS03's Avatar
Yes I've had it happen a few times before, it never became a problem... Maybe experienced it a handful of times for the 4 years I had the car.
Old Mar 24, 2009 | 11:57 AM
545felix's Avatar
My Ride: 05 545/6
thanks
mine did this before I retrofit the nav (and subsequently got a software update.) the brightness is controlled by the photocell on the cluster, it's a light colored dot. if that's blocked (either by shade or some foreign object) it will dim the cluster. I haven't seen it happen since July.
-f
Old Mar 24, 2009 | 01:07 PM
hey3688's Avatar
My Ride: BMW E61 525DSE Auto Touring. 2004 54 plate Metalic saffire Black, Active Steering. 18 Inch Style 124 Alloys, falken 452s Beige Leather Dark Poplar Wood Trim xenon bulb upgrade blutooth phone prep
i have noticed mine doing this a couple of times over the past week 2004 525dse
Old Mar 24, 2009 | 07:03 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
-f
I think the brightness is also controlled by the solar position sensor (the thing that sticks up from the center speaker.) I've seen the display change from dim to bright repeatedly when driving on a road with bright street lights spaced about in a specific pattern...
Old Mar 25, 2009 | 05:15 AM
545felix's Avatar
My Ride: 05 545/6
makes sense. the photocell in the cluster is just to the left of approximately 1700rpm on my tach. perhaps it uses a combination of both readings like the rear view mirror does.
andymax
May 20, 2018 11:32 AM
bestofthebest
Mar 28, 2016 02:47 PM
Henry Peters
Sep 25, 2015 10:15 AM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
