Radio IDrive dead
started about 4 months ago. Radio would cut out and usually after a minute or so would turn back on again idrive screen would die and also start working again after a minute or so. Now neither work. IDrive screen goes white with no text or graphics for about 5 seconds then dies. Radio completly dead 2004 E60 model |
If it was intermittent and is now dead, it sounds like a loose connection that totally disconnected. If you pull your unit out, you will most likely be able to find the loose wire and reconnect it.
Originally Posted by JayArras
(Post 1598656)
As suggested above, did you pull the unit and check for loose or broken connections? I'd start there.
Hi, yes I've checked all the connections on the back of the unit.
Do you have navigation? Try removing the disk and drive that way for a while.
This sounds like the CCC on its way out. Is everything OK when cold at startup?
Originally Posted by NoQuarter
(Post 1599001)
QUOTE=FormerE30Owner;1599006]This sounds like the CCC on its way out. Is everything OK when cold at startup?[/QUOTE] Please excuse my ignorance (I'm new to the BMW scene! What is the CCC? |
Perhaps this can help. The CCC is the Car Communication Centre, which controls the idrive function among other things.
http://www.youcanic.com/guide/bmw-id...cc-cic-failure |
Originally Posted by FormerE30Owner
(Post 1599009)
http://www.youcanic.com/guide/bmw-id...cc-cic-failure I did remove the CCC (I know what/and where it is now!) to again check the plugs etc as currently it is working and I thought I may disturb a loose connection, no joy but I did notice the fan at the back of the unit is not working, could this contribute to the problem? |
