radio cut-out has returned
My Ride: 2006 525i, Alpine White, auto, premium package, nav, cold weather package, euro red reflectors
My baby is only 3 months old. I was having the cut-out problem alot in the first month or so and then suddenly it stopped! I was thinking that maybe it was due to upgrading my Treo firmware (since I've read it may be bluetooth related). Anyway, this weekend it is back with a vengence!
Any ideas?
Any ideas?
If the radio cut out you mention is the around 0,5 sec pause in the radio, try this
Go to the options men? (set I think the word is) and disconnect the traffic bulletin info.
The "T" on the screen must desappears, as well as this sound "jumps"
I hope this helps.
Regards from sunny Spain... today 2 centigrade degress below zero.
I hope this helps.
Well you don't give us a lot of info to work with. L7, AM, FM, ? anything alse. Not even model of car - what kind of help you want?????????
SI B65 26 05
Sound System, Cruise, Alarms, Monitors December 2005
Technical Service
This Service Information bulletin supersedes S.I. B65 26 05 dated October 2005.
designates changes to this revision
SUBJECT
Audio Switches off Briefly when Listening to FM Stations
MODEL
E60, E61 (5 Series) with SA 609 CCC-Navigation
E63, E64 (6 Series)
E90, E91 (3 Series) with SA 609 CCC-Navigation
SITUATION
The customer states that after setting a radio station preset with RDS (Radio Data System) active, and then deactivating RDS, the audio mutes briefly while the customer is driving. CCC-ANT FC "DACA watchdog reset" is stored. Note: With the release of DIS V44 this fault is no longer displayed for this problem when performing a short test.
CAUSE
CCC (Car Communication Computer) software error. The problem only occurred after the vehicles software was updated using CIP 19.1 or 19.2.
PROCEDURE
Perform the following procedure using DIS V44 or higher. This test plan will only be successful if the vehicle has CIP software 19.1 or 19.2 installed.
Perform a short test on the vehicle and diagnose and repair any other faults related to the CCC or the sound system.
Select "Function Selection" from the bottom left menu bar.
Select "Service functions".
Select "Body".
Select "Car Communication Computer".
Select "Add tuner profiles" and then "Test plan".
Select "- Add tuner profiles S6512_50003" under "Own test plan" and page right.
In the "Identification" screen is displayed 2 reminders. Read and then page right:
"This service function may only be used for the Car Communication Computer"
"The CCC must be recoded before this service function is executed". This means that CIP 19.1 or 19.2 must be loaded in order for this test plan to operate correctly. If you have a similar customer complaint and CIP 19.1 or 19.2 are not loaded then this test plan will not fix the problem. Troubleshoot accordingly.
In the "Message" screen is displayed the following. Read and page right:
"The coding of the tuner is being corrected. 2 diagnosis jobs are carried out for this purpose"
In the "Message" screen is displayed the following:
"The tuner coding has been corrected"
End test module and perform quick delete of all faults.
Turn key off for 5 minutes or until driver's switch-block LED goes out.
Check functionality of system for proper operation.
WARRANTY INFORMATION
Refer to KSD
SI B65 26 05
Technical Service
SUBJECT
MODEL
E63, E64 (6 Series)
SITUATION
CAUSE
PROCEDURE
Select "Body".
Refer to KSD
Vman33
03-14-2022 04:43 AM
bestofthebest
01-05-2016 07:47 PM
