R1 Rotors
I bought the R1 concept rotors about a month and a half ago, and i've been getting some crazy annoying squeaks .. it get really bad sometimes, I already tried using the stop squaks sprays, they work for a few hours if that, and then back to squaking. This is killing me, any idea on what to do here?
It is not the rotors or pads that's noisy, it's all about the install. Dod you properly grease the dowel pins that the calipers move on before the reinstalling? Did you grease the backs of the pads? Do both with copper grease and you shouldn't have any noise, or greatly reduced noise. Even OEM's squeal like a stuck pig when they get dusty, not exactly a solution - I know I took my car to the dealer several times when I first got it (my previous 530) and they always said the same thing: "perfectly normal, they squeal when they get dusty"
My Ride: 2006 BMW 550i
do the pads have the noise isolator pads on the backside?
True, but proper install is at least as important as the pads and rotors chosen. The OEM pads have good initial bite but produce an unacceptable amount of dust, and the dust is what the dealer (and many others) say is a main cause of the squealing.
Thanks for the replies gentleman..
I have no clue what pads i have, they were brand new when i purchased the car, and that was about 5-6 months.. so they still new that's why i didnt change them.
The rotors were installed in a shop here in Mia, i took the car back to ask them about the squeak, and one of the guys there told me it was definitely the rotors, they looked 'glazed' ?? .. anyway..
I think is time to go back to OEM rotors? I've noticed when it comes to BMWs you have to stick with OEM ... what a shame, the R1 were relatively inexpensive and they look good.
If the rotors look "glazed" then they were not installed/bedded in properly. Since you used the pads that came with the car then, they probably didn't clean the rotors of their anti-rust coating before install OR they didn't properly bed the pads. You can bed in your pads again easily, simply do 10-12 runs of 10mph-60mph-10mph without coming to a complete stop, do this until you can smell the brakes and when you stop there is a little bit of smoke from the brakes and you should be fine from then on.
There's a local guy selling OEM rotors for $300.. brand new in box... should I ?
![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
