Well, I will try to explain easy as possible and I need an answer from pro people who is really knowing there stuff.
After installation new rear tires in the tire shop, I drove like 300 feet , then decided stop by gas station and check my front tires, but because I'm used to be aircraft tech, my sense was telling me check rear as well, just in case. So I did , and imagine how I was surprised, when on one tire (driver side) was showed 61 psi!!! I know tech was looked on door label and saw 61 psi, but for spare tire, so he did 61 psi!!! Ok, assumed they did couple miles test drive after installation, plus me 300 feet, so Would it be enough to damage a tire permanent, because it's done over inflation on tire? Thanks |
Originally Posted by phlfly
(Post 1388092)
After installation new rear tires in the tire shop, I drove like 300 feet , then decided stop by gas station and check my front tires, but because I'm used to be aircraft tech, my sense was telling me check rear as well, just in case. So I did , and imagine how I was surprised, when on one tire (driver side) was showed 61 psi!!! I know tech was looked on door label and saw 61 psi, but for spare tire, so he did 61 psi!!! Ok, assumed they did couple miles test drive after installation, plus me 300 feet, so Would it be enough to damage a tire permanent, because it's done over inflation on tire? Thanks Always a good practice to "check the tech" !! Isn't that why pilots do a walk-around before getting into the seat :twoup: |
I told, they called me back couple hours later with offer for life tire balance. Well good offer, but I'm going think twice before I do balance there. It can happen with anybody, but Tire Shop?
Yea, we have some people in United Air, that should never worked near airplane and car as well. It's good thing airplanes is almost bullet proof in our days. |
| All times are GMT -8. The time now is 05:16 AM. |
