2004 530i Terminal 15 Dead
Old 12-09-2017, 01:46 PM
alfamaniacs's Avatar
My Ride: 2001 e39 M5 and 2005 545i
Default 2004 530i Terminal 15 Dead
Hey all,
I got in a e60 2005 530i recently that was stone dead apart from doors unlocking, parking lights, hazards and steering and seats adjusting.
*Terminal 30 show 12.83v
*Terminal 15 remains dead regardless of position of key
*Cluster Dead
*Radio and Idrive Dead
I can connect to OBD and access the various modules but cannot activate anything that relies on Terminal 15
DME Scan reveals:
1) Battery voltage 62.89v
2) Code D904 CAS K-CAN line fault
I discovered that the alternator cable was disconnected - attempting to reconnect resulted in a shower of sparks - alternator dead short
Even with key off - something is holding the DME open as the idle control valve continues to buzz.
What I have done:
1) Left alternator disconnected
2) I swapped out the ignition key sensor (screwed to back of switch) - no change.
3) Checked all fuses and relays
4) Disconnected IBC
5) Disconnected MPM
6) Swapped out instrument cluster
My thoughts:
1) One of the modules is corrupting the K-Can Line
2) CAS/EWS/Key is faulty and not activating T15
Your thoughts?
Cheers
Andrew
frankfurt
Bluetooth & Cell Phone Forum
02-16-2019 09:21 PM
petertn
09-25-2011 02:21 PM
anand_rahim
01-15-2009 06:59 PM
1stgen8
08-27-2008 02:09 PM
sapphire 535i
11-27-2007 10:48 PM
Quick Reply: 2004 530i Terminal 15 Dead
